> Can anyone please share the Linear Audio volume 3 where this headphone amp discussed?
Linear Audio | your tech audio resource
I am sure we all respect copyright of Jan and are happy to pay the €3.49.
Patrick
Patrick
RNMarsh amp sikahr layout build manual v1.0
It's a good idea to specify Rf as 1/2 Watt -- happier thermally.
It's a bit of over-kill, but I use 1W Panasonics for the emitter resistors.
Patrick
Now down to 2.49
Jan
Uber lo noise
If you were going to build an over-the-top, cost-no-obect, unber-lo-noise power supply for a headphone amp, what would you recommend? TPS7A33, LT1963, Jung or Didden super-regs are obvious choices. If it could be done without remote sensing I'd prefer that. I'm hoping to save the cost of building and evaluating each, and would rather just use what others have already evaluated.
The LM317/LM337 should be replaced with LT1963A and LT3015 -- you'll be pleased with the results.
The LM317/337 definitely make things worse...
Salas shunt and Jung super reg both popular around here. Both use remote sensing. It depends on the headphone amp/preamp whether they will make a big difference or not.
A suggestion--do the taste test yourself -- piano, male vocals and male speaking voice.
We have a different experience with the F5-HA using 317/337 followed by a cap multiplier.
Admittedly we did not try the LT's.
Patrick
Somewhat like "reverse PSRR" -- the LM317 seems to put harmonics back on the rails:
Unlike the Jung/Didden:
This was a test suggested by one of the respondents to the LA article. It was done months after the article came out so there wasn't any "ex ante" bias.
That is using 317_337 driving the load direct ?
It has been proven that many high NFB "Super Regulators" will oscillate with the F5-HA.
That actually includes my lab PSU, as well as the beloved Salas shunt.
An open loop PSU (cap multiplier or variants) has no such problems.
And the F5-HA has quite good PSRR.
So the verdict is still out, at least for that particular circuit.
I would tend to think that The Marsh has equally good PSRR ?
Patrick
Patrick
Please forgive the novice question, but what was the test setup for these shots? I don't understand how the supply was stimulated - doesn't look like it could be residual rectifier ripple (and harmonics).
This was a test suggested by an LA reader -- just the regulators in the test with a modest load (140mA) , subjected to a 1kHz signal -- it is not a test of Richard's device.
Disregard previous
In retrospect, asking a power supply question in the Marsh thread was maybe not the best of ideas.
I ask that my question be ignored as it's not relevant to the Marsh Amp topic.
...it is not a test of Richard's device.
Thanks. I understand it isn't a test of Richard's device. "subjected to a 1kHz signal" - forgive me for being stupid but it is this bit that I don't fully get. The load is 1kHz sinusoidal? How done? If this is too off-topic then I will gladly transfer the tuition to PM correspondence.
We'll have to move the power supply issue to another thread. I will await the arrival of the new issue of LA to see what issues might be lurking.
Already did :
http://www.diyaudio.com/forums/part...s-capacitor-source-questions.html#post4661397
Patrick
Hundreds of pcb have been produced for this headphone Amplifier. Who have used shunt supplies? And, what are the thoughts from those many others now listening to their favorite music? Are there many using higher PS voltages?
Did anyone else also do the auto-EQ for flat response at the ear that was a part of the Linear Audio article?
THx-Richard Marsh
THx-Richard Marsh
- Headphone Systems
- Marsh headphone amp from Linear Audio
