Headphone Systems Everything to do with Headphones
Marsh headphone amp from Linear Audio
Old 4th March 2013, 11:07 PM   #591
CaféNoir is offline CaféNoir  France
I didn't know that.
Well, no gold then, sorry guys.
Old 4th March 2013, 11:11 PM   #592
Telstar is offline Telstar  Italy
I would be interested only if the boards are 2oz copper. No preference for tinned or gold-plated as my iron has no issues with either.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 5th March 2013, 02:16 AM   #593
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Gold is only used on the traces themselves to protect them. not at the solder joint because gold is quickly leached into the tin/lead and makes for a brittle connection. The solder pads would stay tin or copper.
A solder mask over copper/tin is excellent.
Thx-RNMarsh
Old 5th March 2013, 02:28 AM   #594
rsavas is offline rsavas  Canada
Most board houses offer HASL as a standard plating, lead solder by default, have to specify no-lead if you want that (SMOBC) , extra costs for specials such as Electo-plate or Immersion Gold etc. (SMOGP),tin,silver plate or organic coat (Entek)
I am to understand that they plate nickel over copper before plating gold, this is to prevent leaching of the copper.
Most pcbs end up with around 2oz of copper on outer layers, that is if they have plated through holes, as this plating of copper process adds another oz to the existing cooper foil of 1oz.
Rick
Old 5th March 2013, 03:39 AM   #595
RNMarsh's Avatar
nickel is plated over copper becuase, as I recall, it is difficult to directly plate to copper without the intermediate metal... it would otherwise tend to seperate, peal off easily....It isnt as durable.
[ Same for chrome plating.... cant chrome directly to steel... use nickel then chrome. Or better, copper then nickel then chrome if you want it to really last. Otherwise, it will peal off.]
In any case, you dont want nickel (a ferrous metal) if you can minimise its use for audio conductor and connectors.
Thx-RNMarsh
Old 7th March 2013, 12:28 PM   #596
Files have been sent to production; I ordered 10 PCBs with 2oz copper.
Below is a virtual render of a populated board using Eagle3D.
Old 7th March 2013, 12:34 PM   #597
jackinnj is offline jackinnj  United States
jackinnj's Avatar
That'll be news to the periodic table. Nickel is, if I recall, 2 columns over from iron.
Old 7th March 2013, 01:03 PM   #598
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Mr Marsh likely meant that Nickel is part of what's here called the group of non-noble metals. (aka base metals)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 7th March 2013, 08:26 PM   #599
RNMarsh's Avatar
Not sure what you are arguing about (?). Look into how plating on steel is done and why.
Nickel is wanted for various plating purposes in electronics but not wanted for lowest distortion.
The object of introducing intermediate metals in plating is to close that gap between the base metal and the final metal for reliability of the finished goods. but thats not all.
There are many other details not mentioned about plating and why/what but these are the only ones I am making now.
One example that might be applicable to audio would be durability on contacts... plugs/jacks and edge connectors. When there is a need for a hard metal to prevent wear on repeated insertions. Gold over nickle is another need for a hard base metal. Then there is gold dopping with arsnic to make it hard and not rub/wear off. This is usually what you get with gold... hardened gold. Etc etc etc.
Personally, I would only tin plate the copper or use no plate but only a good solder mask. The fewer the different metals together, the better..... esp. not widely seperated metals on the periodic table.
Thx-RNMarsh
Old 7th March 2013, 08:31 PM   #600
jcx is offline jcx  United States
the purported distortion problem with Ni is from its ferromagnetic properties
clearly Marsh' intent - I don't see the point in the quibble
Marsh headphone amp from Linear AudioHide this!Advertise here!
FS: Meier Audio Corda Headphone Amp jtwrace Swap Meet 5 29th February 2012 12:34 PM
Histoically significant - Phase Linear audio pre-amp bobcul Swap Meet 0 21st February 2012 09:16 PM
Headphone amp with mixed-in telephone audio krfjr1965 Solid State 3 10th March 2010 04:50 PM
Copyright ©1999-2017 diyAudio
