Headphone Systems Everything to do with Headphones
Marsh headphone amp from Linear Audio
Old 9th August 2012, 09:14 PM   #451
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by RNMarsh View Post
I found an eBAY low distortion sine wave signal source on pcb, loaded/built for $39. The fixed 1 KHz signal only has .00005% thd. That works for me. Ordered 2 of them. Look under electronics test equipment.
I measured the units -- 2ea of the 1Khz and found that only the even harmonics are very low. the odd harmonics are not so great -- -88-90db for 3rd and 5th and further down the road is still high. Not better than the AP. rats!
I'll contact the source of these and see what he says.
-RNM
Old 10th August 2012, 01:00 AM   #452
sonidos is offline sonidos  United States
Libertador de la Música
sonidos's Avatar
Jan,
I got the transistors today. Thanks! They arrived in great condition.
Old 10th August 2012, 07:14 AM   #453
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by sonidos View Post
Jan,
Actually you are one short. After unpacking box # 47 (or maybe it was # 55) from the move yesterday, one lonely 210 fell out. I'll get it to you for sure
I'd be curious how they match up, hope they are usefull for you.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 10th August 2012, 02:55 PM   #454
sonidos's Avatar
Jan,
I pulled out the Heathkit IT-18 last night and beta on the NPNs runs about 140 to 160, while PNPs run from about 160 to 180. I'll get plenty of useful ones from the set.
Maybe SY can toss that 1 lonely transistor in the mail when you come to the States for Janneman 2012 Chicagofest!
Old 10th August 2012, 03:54 PM   #455
sonidos's Avatar
Mr. Marsh,
I'll be checking for Vbe this weekend. Details to follow.
@jackinnj:
Coming up with a revision to my board will be cinch for those SMT fets..plenty plenty in stock at Mouser. I'll build a TO-92 version and an SMT version. Plenty of boards in my parts bin and plenty of etch solution.
Old 10th August 2012, 05:27 PM   #456
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Mr. Marsh,
@jackinnj:
For the F5 boards i had burned in China i allowed for use of SMT JFETs -- i should've thought of that when I did the headphone boards, but hadn't realized that there was a shortage of TO-92 parts...and as i mentioned previously, you could use GR rated 2sk170's or bf862.
Old 10th August 2012, 06:35 PM   #457
sonidos's Avatar
On my part, it's a hard-headed approach to staying as faithful to the article.
But I'll shed no tears if I have to use the SMT parts.
Old 12th August 2012, 05:03 AM   #458
RNMarsh's Avatar
-RNM
source says there is nothing wrong with them... must be my AP needs calibration... ??
Old 13th August 2012, 06:24 PM   #459
sonidos's Avatar
yes, as a rookie, I was tempted to buy used stuff on ebay dirt cheap. Then I started to realize how will I know if it's defective? I later read somewhere to pay for a re-calibrated unit.
Update - the MOT fets I bought are junk. As soon as I put them on my breadboard to test Idss, they became extremely hot. Boy oh boy...
So I also worked on the SMT layout and I'll order some of those Fairchild SOT23 fets. But I bet I have close enough matching on those FETS I found in FLA and in Thailand. So on the fets, I'm good to go.
Old 13th August 2012, 10:36 PM   #460
sonidos's Avatar
Default SMT version
On the left channel, I laid it out for the smt versions of the jfets. I noticed on the Fairchild Semi datasheet that drain and source are inter-changeable. So it must be symmetric it seems.
Also note that I added film caps from rail to ground and also a film cap that goes from rail to rail. Mr. Marsh mentions this in the article. I lucked out and got the last of the Wima PPS box caps in stock. These are the Wima MKI series. Nice and small with 5mm lead spacing.
Marsh headphone amp from Linear AudioHide this!Advertise here!
FS: Meier Audio Corda Headphone Amp jtwrace Swap Meet 5 29th February 2012 11:34 AM
Histoically significant - Phase Linear audio pre-amp bobcul Swap Meet 0 21st February 2012 08:16 PM
Headphone amp with mixed-in telephone audio krfjr1965 Solid State 3 10th March 2010 03:50 PM
