Headphone Systems Everything to do with Headphones
Marsh headphone amp from Linear Audio
Old 30th July 2012, 04:21 PM   #431
sonidos is online now sonidos  United States
Libertador de la Música
sonidos's Avatar
Jan,
Funds have been sent. Thank you.
Old 8th August 2012, 06:19 AM   #432
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
how is the build going?
Old 8th August 2012, 02:12 PM   #433
sonidos's Avatar
Default Warp speed? Nope...
I ordered those 10 cent jfets and they are all dogs. Jan Didden shipped the MJE's asap but they haven't arrived. Taking all the patience I can muster!
I am going over the layout of the board to be sure I haven't missed anything. It's coming together. I have about 90% of the parts now.
Old 8th August 2012, 03:37 PM   #434
DSP_Geek is offline DSP_Geek  Canada
Originally Posted by janneman View Post
Javier, if this is the cap after the reg, you normally don't want it to be super-low ESR. The ESR part is required for loop damping to enhance stability.
Very high quality film caps are a no-no here.
I have a prototype 400VDC reg where I actually had to insert a 1 ohm R in series with the output cap to quiet it down - my electrolytic was simply too good
jan
Yup. One can do a back-of-the-envelope estimate of required ESR by looking at the regulator spec, inferring ESL from the output impedance curves, and setting R = ESL / C. The humble 7815 / 7915 parts come off fairly well by that measure, amusingly enough.
Old 8th August 2012, 04:58 PM   #435
sonidos's Avatar
I learn something every day from this forum!
Old 8th August 2012, 05:25 PM   #436
sonidos's Avatar
Default general board layout
Here is what I've concocted. Funny, but after putting the rat's nest together, it all started to take shape just like Mr. Marsh's board.
Old 8th August 2012, 07:09 PM   #437
Unomas is offline Unomas  Spain
Hi, mine is going on step by step. Right now I'm concentrated on the PSU and later on I'll started the HeadAmp. I'll report on the evolution. As for the HA PCB, I'll be using Jack's design (after all he started this very wonderful and informative thread ).
By the way, I think you mentioned earlier on the thread that this design is optimized for low-Z headphones. Just in case we would need it adapted to higher Z ones (like the old AKG K340 or Sennheiser HD800, both of them around 300 Ohms), could you please give us some directions to adapt the design? Thanks in advance.
Javier.
Old 8th August 2012, 07:16 PM   #438
sonidos's Avatar
Javier.
Yes, I have Senn 300 ohm phones as well. I asked him before about adjusting resistor values but he warned me that I couldn't increase it that much more. It's in one of my previous posts somewhere. I believe it was R8.
Old 8th August 2012, 10:53 PM   #439
Thanks Javier for your answer. Well it might not be the best option for this type of headphone, but anyway it may be helpful to know the limits for this little wonder:
- Maximum Vout for a typical +/-12v or +/-15v supply (considering the use of well matched pairs)
- Maximum Iout while working in class-A and absolute limit (considering the use of adequate heatsinks to avoid dangerous temperatures on the final TRT)
Javier
Old 9th August 2012, 01:06 AM   #440
RNMarsh's Avatar
It all depends on the efficiency of the headphone driver; its max input before damage or gross distortion sets in. Give it a try first with 300 Ohm headphone as-is. then tell me.
The 30 Ohms just means it can drive lowZ without distortion. many amps cant do this and IC amps cant do it at all.... even with IC buffers. It's just takes too much current.
I didnt mean that it wouldnt do as well with higher Z. In fact, the thd is even lower into higher than 30 Ohms. I am having a hard time measuring the level.
All -- keep us posted on what you hear when it gets done or if there are problems or different power supplies.
The max power is about 10-12 W... heat sink dependant.
Thx, RNM
Marsh headphone amp from Linear AudioHide this!Advertise here!
FS: Meier Audio Corda Headphone Amp jtwrace Swap Meet 5 29th February 2012 11:34 AM
Histoically significant - Phase Linear audio pre-amp bobcul Swap Meet 0 21st February 2012 08:16 PM
Headphone amp with mixed-in telephone audio krfjr1965 Solid State 3 10th March 2010 03:50 PM
