| Headphone Systems Everything to do with Headphones |
#361 |
@jackinnj
You close to giving a green light to distribute boards? |
#362 |
What about this.
Headphone ground return wire goes directly to audio ground and the left/right SGD are each connected to the audio ground through 10R//100nF. The audio ground is then directly connectd to regulator/cap multiplier ground. In my opinion this should be the best solution. |
#363 |
BTW- I didnt use any 10 Ohm resistors in my headamp sample and have no grounding issues..... just follow the current loop (s) to see if they intersect one another...or share a common path. -RNM
#364 |
Yes, jackinnj introduced the idea in an addendum to your pcb.
One question that another member brought up several posts back. In the matching of pnp to npn, many have told me that it's a pipe dream to get matches that are very close. I know when I refurbed my Adcom 535 amp, I went the distance to match. Finding PNP to NPN matches was darn near impossible. NPN to NPN or PNP to PNP was a piece of cake...the trannies came from the same batch and all matched very closely. I think the member who asked first said he planned to by 1000 of them, if IIRC. ![]() How close were your matches? |
#365 | |
Last edited by RNMarsh; 15th July 2012 at 08:50 PM. Reason: matching made easier - |
#366 |
Thanks for the additional details. I bought 8 pcs. of the p-fet and then started to think...that ain't gonna do it!
I did find the jfets at Futurelec for about 10 cents each. I bought about 40 of each, so I'm hoping to get in the neighborhood. BJTs are all USA made, so that should do the trick and get good results. |
#367 | |
Now I will try with Onsemi (the other where Fairchild's). I will report later on the results. I hope (well better say PRAY) this time will have better luck... Javier |
#368 | |
#369 | |
As I said in my previous post, I tested them using a Peak Atlas DCA55. They have perfectly equal Vbe, but Hfe was a whole different story: - MJE200: From 140 to 170 - MJE210: From 210 to 225 I bought them from a reputable (well I think so...) source like Mouser and they are from a reputable manufacturer (again, I think so...) like Fairchild. This time I will try with On Semiconductor. I will tell you later on the result. Javier |
#370 | |
| FS: Meier Audio Corda Headphone Amp | jtwrace | Swap Meet | 5 | 29th February 2012 11:34 AM |
| Histoically significant - Phase Linear audio pre-amp | bobcul | Swap Meet | 0 | 21st February 2012 08:16 PM |
| Headphone amp with mixed-in telephone audio | krfjr1965 | Solid State | 3 | 10th March 2010 03:50 PM |
