Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 14th June 2012, 02:06 PM   #261
sonidos is offline sonidos  United States
sonidos's Avatar
Originally Posted by jackinnj View Post
I thought I had posted this -- 2N5460 is available from Mouser. They have a couple hundred in stock.
I missed that, thanks! Well, on the other jfet I guess I go for the Chinese jfets and cross my fingers!
Old 14th June 2012, 05:28 PM   #262
sonidos's Avatar
Update: I just purchased the 2n2547 jfets from Tayda2009 on ebay, since they have a good rep. After I get all the parts in, I'll report if I had any problems with matching or Idss.
Old 15th June 2012, 04:25 AM   #263
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Originally Posted by coluke View Post
open loop performances of the DB-CM-DB architecture are quite amazing
Under simulation at any rate, my results bear this out 100%.
RJM Audio (phonoclone.com / G+)
Old 15th June 2012, 05:08 PM   #264
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Is there a compliment to the 2N2547?
Old 15th June 2012, 05:12 PM   #265
RNMarsh's Avatar
There is some gain there... Not optimized... should have lower distortion. Remove R6 and then it will be open-loop and then retest.
Old 15th June 2012, 05:54 PM   #266
Telstar is offline Telstar  Italy
psst... Complement. You do this mistake in the article too.
Jan, note it for reprint
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 15th June 2012, 05:59 PM   #267
jan.didden's Avatar
Yeah, I missed it!
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 15th June 2012, 06:10 PM   #268
sonidos's Avatar
It must be the day for typos. I meant 2N5457.
Old 15th June 2012, 11:20 PM   #269
coluke is offline coluke  Italy
It seems that NTE457/NTE460 by NTE Electronics are equivalent to 2N5457/2N5460 - Newark has a few of them in stock.
L.
Old 16th June 2012, 12:44 AM   #270
jackinnj's Avatar
Lots of devices will work on the front end -- but be mindful of the pinouts! I will try on Sunday. I have some sk170gr/j74gr matched up.
FS: Meier Audio Corda Headphone Amp jtwrace Swap Meet 5 29th February 2012 11:34 AM
Histoically significant - Phase Linear audio pre-amp bobcul Swap Meet 0 21st February 2012 08:16 PM
Headphone amp with mixed-in telephone audio krfjr1965 Solid State 3 10th March 2010 03:50 PM
Copyright ©1999-2013 diyAudio
