| Headphone Systems Everything to do with Headphones |
#211 | |
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#212 | |
Accuracy also the same. Induction is double in series and half parallel, but capacitance is double in parallel and half in series. Voltage coefficient effect is half in parallel. So it all depends. If you are concerned about voltage effects go for series - each only sees half the voltage. jan
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#213 | |
The above conflicts I assume a typo and you mean Voltage coefficient is half for the series case. Thanks -Antonio |
#214 |
When you place two resistors in series the inductance increases if they are inline. If you double them back to form a "U" then the inductance decreases! So using two in series can result in lower capacitance and inductance!
However an important issue is thermal matching. Due to tempco there is some third order distortion present. If the feedback voltage dividers are run at vastly different power levels then the thermal lag between the distortion can result in a small level of 9th harmonic distortion. So using a 4R/R divider offers a bit of an improvement. |
#215 | |
jan
#216 |
Speaking of output transistors -- the MJE200/210 hfe will vary from ~150 to 210. I found that the 2sb649ac/2sd669ac varied somewhat less. These have a higher ft than the On-Semi devices.
I think that the -3dB bandwidth which Richard stated in the article (25kHz) is extremely conservative as mine goes out quite a way... |
#217 | |
Are you refering to Open Loop BW? That 25kHz was for Open-loop BW. Last edited by RNMarsh; 31st May 2012 at 07:51 PM. |
#218 | |
I find the largest limitation is not amps and preamps but the source material. The HD downloads and a great DAC give the best sound I've ever heard to date. Really lets you know just how good your amps and preamps are capable of sounding. With this headphone amp, you will hear the closest sound to a master possible. [ at the present time, i use Senn HD800 and HiFiMan HD500 mostly... a few others are here but not used as often] |
#219 | |
In case anyone is wondering, I have used many sim programs and have MicroCap as my favorite. However, this circuit was not developed using any sim programs. Sim programs are great learning tools and useful for some things, but after awhile you just dont need it anymore if you've done enough circuits. This one just isnt that complex.... very refined, yes. Other than that -- Thx, Richard |
#220 | ||
Yes I know what you meant, thanks. But if you consider the 2 series resistors as one equivalent R, then the voltage coefficient for this R is effectively half of each of the individual's. Quote:
Simon, How does doubling back decrease the capacitance? It would seem to me that doubling back would add a small lead capacitance as the potential extremes are closer to each other. Thanks -Antonio |
| FS: Meier Audio Corda Headphone Amp | jtwrace | Swap Meet | 5 | 29th February 2012 11:34 AM |
| Histoically significant - Phase Linear audio pre-amp | bobcul | Swap Meet | 0 | 21st February 2012 08:16 PM |
| Headphone amp with mixed-in telephone audio | krfjr1965 | Solid State | 3 | 10th March 2010 03:50 PM |
