| Headphone Systems Everything to do with Headphones |
#111 |
Umm..no, sure didn't. Couldn't pass up those bargains just across the border!
To RNMarsh, after we all get our hands on building the head amp, I'll definitely put up some feedback on this thread. I have a pair of Senn HD580s that I hope kick some *** with this circuit. Last edited by sonidos; 23rd May 2012 at 05:46 PM. Reason: added a strategic letter |
#112 | |
#113 |
#114 | |
You have made an assumption that is clearly not the case. There are several cases you might want to consider: 1. There really are folks here who spend almost no money as their budgets are limited. 2. It just might be possible there are Ego's hanging out here that are larger than mine and so don't recognize the advantage of reading others contributions. 3. There are those who as long as the milk is free, won't buy a cow. So what if the milk is a bit sour (Or the content is not at as high a standard.) 4. Then there are folks like me. I won't buy any new printed content when I don't have time or room for it. I'll buy material when things slow down! I still need to build 6 to 10 more bookshelves! 5. Then there those who are here to primarily show off. You for some strange reason assume that everyone who writes they have a Royce really does. Painting RR on the hood of a Yugo just isn't the same. 6. Finally there are some who just want to build stuff and there are lots of free projects. They don't get that some of the designs are really not very good. Oh I just re-read #2, My mistake there can't be Egos larger than mine! ES Now as proof just look at some of the comments on the circuit discussed here by folks who have not seen the article, don't know the author's history and generally don't have a ticket to the clue train. (Currently found in ant issue of L.A.) |
#115 |
Sure Ed, all good points.
I didn't per se literally mean chosing a $ 100 cap for an LA volume, rather I wanted to contrast the easy spending on parts without iron clad reasons, versus spending something on increasing your understanding. I'm sure you'd agree on that in principle. Now if you'll excuse me, I must go paint 'Lotus' on my Chevy Cruze... jan
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5! |
#116 |
As far as i can see it the buffer has 100% feedback in a local loop.
#117 | |
#118 |
So, is 0.0007% good enough? Four transistors and two diodes (which may count as transistors since they are CRD's). Since there is no loop feedback to reduce the output impedance, then you really have to juice it up to get a low enough impedance to drive 30 ohms at low distortion. Output level is 731mV rms. At 1V rms output, distortion goes up to 0.001%. This is across 30 ohms of course, as you wanted. These are Mr. Cordell's transistor spice models, btw.
#119 | |
#120 |
| FS: Meier Audio Corda Headphone Amp | jtwrace | Swap Meet | 5 | 29th February 2012 11:34 AM |
| Histoically significant - Phase Linear audio pre-amp | bobcul | Swap Meet | 0 | 21st February 2012 08:16 PM |
| Headphone amp with mixed-in telephone audio | krfjr1965 | Solid State | 3 | 10th March 2010 03:50 PM |
