| Headphone Systems Everything to do with Headphones |
Hi. I am planing to make this amp:
![]() DIY Simple Headphone Amp Tutorial: Class A Mosfet Headphone Amplifier These is also a schemetic there but I dont understand anything forum it ![]() Any way, I have a couple questions as a total noob. Diode Line Up; 1) 4 x 1N914 Diode Mosfet Chip Line Up; 1) 2 x IRF 513 Mosfet Theese parts are not avalaible in the store where I am going to buy my parts. In that store, integrated parts are not categorized, listed by their header. For exp. NE-NJM-TL-IRF. Becaouse of this I cant choose any optional Diode. 1N diodes IRF Parts All integrateds If you could choose diode and mosfets for me from the links up there, I will be very grateful. I have no ideade what to pick. ![]() The headphone I am going use with this amp is Sennheiser HD 518. Has 50 ohm impedance. Volume level is almost enough when listening at %100 volume. So I mainly expect increased sound quality from this amp. Any tips will also be useful. THANKS!!! (Sorry for my bad english) |
#2 |
If its any help I used irf610's in mine and it worked fine, the diodes were generic 1Amp
I use them simply because I had some on the shelf cheers |
#3 |
Is this scheme has something wrong? Some people I know reported that its wrong?
Man, I should learn to read normal schemetics asap. For now, I only understand from this colorful scheme
#4 |
Well, the negative supply is connected to ground, which obviously wouldn't work. Best leave out the -9..-15 V altogether (the original schematic doesn't have that either).
If you do want to build something with split supplies later, I recommend replacing the 20R source resistor with a current source. Much better power supply rejection and distortion. |
| Configuring an AB class amp to work in pure A class | jrme | Tubes / Valves | 5 | 23rd February 2010 06:31 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| why p-p amp RL for class B is 1/2 the class A load? | walter33333 | Tubes / Valves | 2 | 12th February 2008 04:56 PM |
| Class D amp? Digital amp? or traditional Class A? | rockytro | Solid State | 21 | 23rd May 2006 12:40 AM |
