Headphone Systems Everything to do with Headphones
Looking for a new project. Anything similar to the Schiit Lyr?
Old 28th April 2012, 12:52 PM   #11
regal is offline regal  United States
Yes but the concept is long overdue, especiall with the ortho headphones int the mix now. Believe me I have looked hard at an SET design and short of a GM70 a clean 2W into 38 ohms isn't happening.
Old 28th April 2012, 02:35 PM   #12
simon7000 is offline simon7000  United States
Originally Posted by KatieandDad View Post
What an unfortunate choice of name.
In English that is Sierra (S) Hotel (H) India (I) Tango (T) Liar.
When I saw the pot listing I thought it was a bad joke!
The National LM4562 has changed part number. It seems it is pronounced to sound like an offensive term in China!
Old 28th April 2012, 05:25 PM   #13
rob g is offline rob g
In a way it is a great name for a piece of Hi-Fi, designed to sound brutally revealing.
It claims to be very bad at being inaccurate, cos it's a sh1t liar!
Old 29th April 2012, 03:15 AM   #14
I did a little probing on my new Lyr, the tube stage is a simple common cathode, resistive loaded plates with the shared cathode ccs, operating point with my less than fresh amperex orange globes is 110V anode, 2.7V cathode, which gives me about 3mA per tube . Its a good design, not some enemic chinese SRPP run 100V B+. Its quiet with Grados so the B+ regulation must be good stuff. The p-p mosfet output is well laid out. The coupling cap in front of the output stage is a decent Wima 4.7 MKP4. If I hear a room for improvement the bass seems a bit too snappy/harsh at high high power levels (fine at normal levels).
I guess a DIY version could be done for about the same price without a whole lot gained. Would do a little better with a more linear operating point, more like 125V/5mA.
I would be more interested in an no expense tube hybrid headamp. Maybe tube rectified/Salas HV B+ to 4p1l (coleman reg), to lateral mosfet p-p type buffer. Would be expensive and time consuming but could be worth it. I am surprised there isn't much interest in building a DIY ortho amp, everyone seems content to plug them into antique Sansui receivers
Old 6th May 2012, 06:43 AM   #15
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Tube+MOSFET hybrid headphone amps are bit ... uninteresting. They are basically two fully independent sections, one high voltage, low current, the other low voltage, high current. Since the don't ideally share a common power supply, the circuit design quickly devolves into a tube preamplifier and a MOSFET headphone buffer that just happen to share a common chassis.
As for the Lyr, I'm sure it's a solid-by-DIY-standards design, given it's heritage. I'm most interested to know how the dynamic biasing is done:
It works by sensing the current flowing through the output stage, and dynamically reconfiguring from Class-A single-ended to push-pull Class AB.
I've seen amps with this general design claim surface a few times over the years, but never seen a circuit schematic to tell me exactly what is being done.
RJM Audio website|blog
Old 6th May 2012, 02:24 PM   #16
alfa147x is offline alfa147x  United States
I know they're using some type of ic for the switching. I'll order one soon. I'll post when I receive it. Then we can decipher it together.
Old 6th May 2012, 02:29 PM   #17
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
The Ford Capri had to be renamed because - apparently - Capri is an oriental name for a lady of the night.
Old 7th May 2012, 12:44 AM   #18
Not all hybrids are unitnteresting, with these new orthos we need to swing upwards of 17Vrms, that equivalent to a 35watt amplifier for speakers (without has much current delivery). If you had looked at the EHHA it is not a tube stage plus separate buffer. Its a differential input-VAS-currentbuffer all shared powersupply with global feedback, just has a tube differential input instead of jfet.
Even the lower model orthos need a solid 6Vrms swing into 38 ohms which is a challenge for SET tube folks.
I think the dynamic biasing just means the output stage is push-pull biased around 100mA, and when the volume/load high enough it goes into class B just like any heavily biased class A push-pull stage. But I didn't look at the mosfet stage, the Lyr does fit your tube preamp + mofset stereotype.
Old 6th May 2013, 10:27 PM   #19
john57 is offline john57  United States
The very best sounding hybrid tube amp that I have heard is the Cavalli Audio Liquid Glass Amplifier at $3500 which has about the same power as the Lyr. Does anyone knows how that is designed?
Old 7th May 2013, 04:28 AM   #20
Lord Soth is offline Lord Soth
Yes.... For a bargain price of only $3,499, the schematics are all yours.
Looking for a new project. Anything similar to the Schiit Lyr?Hide this!Advertise here!
WTB original tonearm (or similar) for Project 6.9 turntable kmj Swap Meet 0 12th November 2010 12:31 PM
I'm Looking for this Similar Schematic ! calico88 Tubes / Valves 7 21st April 2008 03:48 AM
Any DIY project similar in sound to Paradigm Atom? manxam Multi-Way 6 22nd March 2007 09:39 PM
re-using Sillpads and similar AndrewT Parts 0 22nd January 2007 02:20 PM
ACI Jaguars or similar project info. Phil M Multi-Way 6 2nd May 2002 01:33 AM
