Spud amps - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 28th March 2012, 07:08 AM   #11
Stixx is offline Stixx  Germany
Stixx's Avatar
Navyblue, you have PM.
Old 29th March 2012, 01:38 PM   #12
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
The central idea for these amps is that they be cheap. What this means in practice is salvage iron: if you are paying the going rate for new output and power transformers, as well as perhaps filter chokes, you'd be better served by a better circuit with a proper driver stage and higher power, better-sounding output tubes.
So, essentially, you usually end up designing the circuit around whatever iron you accumulate off ebay or wherever, and the tubes in your drawer. If it's for headphones rather than speakers, you have to pay a bit more attention to hum and noise. If it's for desktop speakers, pretty much anything goes.
The basic, fundamental problem is the output transformers: if they are small and cheap, there's no bass response and the sound is lo-fi. If they are large and expensive, you are wasting your time with crap tubes when you should be building a 2A3 DHSET.
By the way, the single stage design is a low-rent shortcut, not a "less-is-more" hi-fi thing. Driving the output stage directly from a 50k or 100k volume pot will work, just, but it is unlikely to sound very good. Volume dependent frequency response ... practically shouts "student dorm".
RJM Audio (phonoclone.com / G+)
Old 29th March 2012, 06:31 PM   #13
I get the impression that SET amps are not known for their technical abilities, but rather for their coloured sound. Am I right to think that?
Say I am getting a custom transformer from say Electraprint, so you suggest that I should be looking at 2A3 tubes? Is there a schematic out there that you can point me in the direction of?
Thanks.
Old 29th March 2012, 07:02 PM   #14
Stixx's Avatar
Are you trying to make a point with your biased ...err.. statements?
Old 17th March 2014, 05:48 PM   #15
Bigun is offline Bigun  Canada
Bigun's Avatar
I believe SETs can be designed to be sound neutral sounding even if not of the lowest distortion.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 18th March 2014, 02:54 PM   #16
mark02131's Avatar
Maybe you can help me understand As the volume goes up and down the frequency response changes?
DHTROB made one of these with 5842 tube and says it sound amazingly good but from what your saying that should not be the case.
Old 20th March 2014, 12:15 PM   #17
I guess he was referring to Miller effect. Plate-to-gate capacitance appears magnified by voltage gain (and so does any voltage-dependent variation, if applicable).
One would have to consult the datasheet and do the math (RC lowpass). Maximum output impedance of a pot driven by a low-impedance source is Rpot/4.
Old 16th April 2014, 08:48 PM   #18
jpak is offline jpak  United States
jpak's Avatar
Originally Posted by Stixx View Post
Dsavitsk's spud amps are well thought out... though I haven't built them I would recommend them.
For the Torpedo you could check the HeadFi site... there's a few discussions and an official build thread.
Then I have built quite a few headphone amps myself... the last one being a spud amp based on the german C3G transformer coupled and fed by a Salas shunt reg. See schematic attached --> it has been refined since and sure sounds gorgeous.
Which 10k:300 OPT did you use, I take it was custom order?
Old 18th April 2014, 03:56 PM   #19
Stixx's Avatar
Jpak,
I wound up using Lundahl LL1689... there's a pic somewhere in the Gallery.
Or check out my sig
www.original-ton.net
Old 22nd April 2014, 07:51 PM   #20
jpak's Avatar
Jpak,
Or check out my sig
Thanks for the info! I am a HD800 fan as well
Th spud jblauvelt Subwoofers 75 28th May 2015 10:31 PM
Spud issues - a little help, please tomchr Tubes / Valves 11 13th January 2010 05:10 PM
Spud anyone? Tubelab_com Tubes / Valves 88 12th January 2010 01:22 AM
Is this a Spud Amp ? mod_sonic Tubes / Valves 7 12th July 2006 12:11 PM
intro spud spudspud Introductions 2 19th March 2005 07:45 PM
Copyright 1999-2017 diyAudio
