Headphone Systems Everything to do with Headphones
Headphone amp  12AU7 art PCB Design
Old 15th March 2012, 05:07 PM   #1
tigersilver is offline tigersilver  Thailand
tigersilver's Avatar
Default Headphone amp 12AU7 art PCB Design
a design published over at DIY Audio Projects NP-100v12: 12AU7 (ECC82) / IRF510 Headphone Amp
append
transformer 12V 1-3A
Capacitor
10000uF x2
0.1 UFx2
regulator MC7812
BRIDGE RECTIFIERS BR1006
I'm very bad language.
Sorry, for a little less detailed.
Old 30th March 2012, 03:55 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I strongly dislike mixing tubes and sand in the same circuit. Why a 12AU7 in between MOSFETīs, and ICīs?. Why not to put a JFET in place... and maintain all solid state? Or make a WCF and use only tubes?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 30th March 2012, 05:24 PM   #3
qusp is offline qusp  Australia
qusp's Avatar
yeah because Erno Borbely really didnt have a clue what he was doing..... neither was the blue hawaii electrostatic headamp a passable idea (project in original DIY form), Kevin Gilmore and John Broksie clearly have rocks in their heads....
I think use whatever is convenient and does the job well.
nice work on the PCB art tigersilver! ive often thought about mixing my graphic design/lithography with electronics to do something like that, but i do worry a bit about eddie currents and strange loops caused by the odd shapes
no good? its thought by many to be one of if not THE best headphone amp available and I for one cannot wait to hear my friends fantastic build with his O2 down the bottom (nattonrice, also a member here) kudos Tom its one of the most impressive headphone amp builds ive ever seen
I give you the Blue Hawaii and Nattonrice's slightly modified DIY version using original BHSE PCBs but with a solid state CCS load
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 16th May 2012, 10:21 AM   #4
Serg84 is offline Serg84
Serg84's Avatar
qusp, very nice amp! I want to ask your advice on this amp. I am having serious problems with his work. Posted in pm.
Old 12th August 2013, 06:12 PM   #5
roline is offline roline  United States
roline's Avatar
I've done many sand/glass headphone amps, They all worked very well and were black hole quiet, no noise. I tried a low voltage tube differential input mosfet output opamp approach and it is fun to listen too. It uses the tubes heaters as the pull down current on the output mosfet, so the heaters runs at 12 volts with audio AC on it.
I've also done hi voltage tube and Mosfet output designs with DC supplies for the heaters and finally decided on trying a PP tube style amp, should be able to squeeze 1 watt class A out of it.
There are so many ways to accomplish the same goal. Each will have a design bias and may even criticize those who do not follow their beliefs. If you have an idea, try it you may be surprised at the outcome. Always enjoy the process of creation!
SO many tubes, SO little time!!!
Headphone amp  12AU7 art PCB DesignHide this!Advertise here!
Hybrid headphone amp with 12AU7/ECC82 IRF510 and LM317 Rodeodave Headphone Systems 6 30th December 2012 05:06 PM
12au7/ fujtsu mb3732 headphone amp preludefan Headphone Systems 2 16th September 2011 12:29 AM
12AU7/EL84 Headphone Amp sorenj07 Headphone Systems 8 5th February 2008 04:44 PM
12AU7/12BH7 Headphone Amp sorenj07 Headphone Systems 42 16th June 2007 12:14 AM
