| Headphone Systems Everything to do with Headphones |
Been looking around today for some cool enclosures to go with the o2 amp.
Have been finding some cool stuff. Been checking out allied, eBay, silicon ray but would like some suggestions. I will just edit the cad drawing of the front plate to reflect the need for whatever enclosure I end up deciding on. |
#2 |
No suggestions?
#3 |
Go with the proven case in in the bill of materials. Then, update the case by buying some slightly larger recessed head hex bolts and tap the holes with the correct thread tool. This will make the process of getting back into the case much easier since you'll have established threads.
Also, keep in mind there are many front panel options available - clear plastic, silver aluminum from JDS Labs and even now some bamboo panels are starting to appear.
Nothing beats the smell of solder vapors in the morning. |
#4 |
#5 | |
#6 | |
#7 | |
As mentioned before, the standard case can be re-tapped with a larger and proper thread size so you can install a variety of bolts to hold the plates on. My "mini" bolts require an allen wrench to tighten them down. Plus, they're black and look a bit more professional than even the black phillips head screws.
#8 | |
the dac is only available from a retailer because they have to specially order the parts in bulk. |
#9 |
I think I'm gonna order the jds labs PCB and power supply
Standard box enclosure: Box Enclosures - New Page And standard front plate with no writing that he has on his website. I like the clean loom. Only problem is I'm not at home for a few days, staying at my girlfriends house, and I can't get the cad design to come up on my phone. |
#10 |
| O2 amp Australian parts GB | BlueFusion | Group Buys | 1057 | 12th May 2012 02:39 PM |
| Help with BantamDAC and O2 Amp | jschristian44 | Headphone Systems | 2 | 27th January 2012 05:22 PM |
| O2 Headphone amp for sale! | agdr | Vendor's Bazaar | 10 | 9th December 2011 03:05 AM |
| o2 amp building | jtktam | Vendor's Bazaar | 0 | 3rd November 2011 09:52 AM |
| Questions before getting parts for the O2 Amp | dewasiuk | Headphone Systems | 3 | 12th September 2011 04:33 PM |
