Headphone Systems Everything to do with Headphones
Suggestions, Opinions needed
Old 27th February 2012, 01:48 AM   #1
Mikett is offline Mikett  Canada
Default Suggestions, Opinions needed
I am clearing out "junk" I have collected over the years in old circuits that I am no longer using.
I have some ICs, TL071, AD844, AD797, NE5534 (signetics) and finally a pair of LH0002 buffers.
I also have on a perfboard a 7815/7915 power supply with space for the four ics required. Some 100K stereo log pots and a 25VCT 100ma transformer.
I am thinking of making a current boosted op amp headphone amp with the above.
Can anyone suggest the best op amp from the list above to use with the LH0002 buffer and pot. I am thinking a non inverting stage followed by the buffer. What about including the buffer in the feedback or not?
Thanks for your thoughts.
Old 27th February 2012, 02:12 AM   #2
gootee is offline gootee  United States
Why would you ever not want to have the buffer(s) inside the feedback loop?
Old 27th February 2012, 02:35 AM   #3
Well I don't know, so I am wanting some views.
Old 27th February 2012, 02:03 PM   #4
sgrossklass is offline sgrossklass  Germany
Do you only have one of each of these opamps? Or (hopefully) pairs?
Some of these parts are quite fast and I imagine would take some skill to implement well on perfboard.
IMO 100k pots are too high in value to be useful for anything high performance.
Assuming there are two opamps of each, this is what I'd do:
5534 (compensated for unity gain) as an input buffer --> 2k2 pot --> AD797 or AD844 for gain stage + LH0002 buffer inside feedback loop (may need feedback as suggested for capacitive load driving to get opamp GBW as seen by the buffer down - buffer bandwidth should be a good bit higher than opamp GBW/voltage gain).
Old 27th February 2012, 02:25 PM   #5
I have pairs, With regards to the suggestion, I don't have enough space on the perfboard to implement the three IC arrangement with the forward buffer. So I am thinking of dropping the buffer as it will be driven by a Asus Xonar DG soundcard. I am thinking of using a resistor gain setting of 4.7K/1K. If so, any suggestions as to how much capacitance I should put across the 4.7k? This contraption will drive a pair of Koss Portapros and occasionally Sennheiser HD598s until I build up the Wire.
Thanks again.
Suggestions, Opinions neededHide this!Advertise here!
Crossover Help And Opinions Needed ka7niq Multi-Way 2 12th November 2006 01:49 PM
3 floorstanders-opinions needed mlankton Multi-Way 3 12th September 2006 12:35 AM
ASAP opinions needed...pls? whiteSE Solid State 3 29th October 2005 10:03 PM
Suggestions for the best preamp to match the Aleph3 !!! Opinions please !!! safetyman Pass Labs 6 19th August 2005 10:28 AM
Subwoofer opinions needed! chr Subwoofers 4 17th November 2002 09:44 PM
Copyright ©1999-2017 diyAudio
