Headphone Systems Everything to do with Headphones
Thor, an all discrete Lateral FET Headphone Amplifier.
Old 20th April 2012, 06:34 PM   #101
Neutrality is offline Neutrality  Denmark
You want measurements?
If all goes well I might have some 1K and 20K FFT's on Monday.
I will test the amp with a 32 Ohm load and 1V RMS, maybe 2/4V RMS as well.
Also, If I have time for it I might include a frequency response plot.
But I wont promise anything.
Old 21st April 2012, 01:13 AM   #102
regal is offline regal  United States
Just meant w/ a sound card 1Vrms out tells a lot. No biggy just curiousity.
Lateral mosfet headamp is a bit of an innovation I think.
Old 21st April 2012, 08:40 AM   #103
Well, I have access to a few different spectrum analyzers at work so I should be able to do better than a soundcard FFT.
I don't know if it is an innovation as such, but from googling there doesn't seem to be any similar designs with Lateral FET's.
Old 21st April 2012, 03:45 PM   #104
I have sold a few PCB's so far but now that I'm done with designing all the PCB's and everything works as it should I have a bunch of PCB's left from V1 of my amp.
They are all fully functional.
Only issues are :
Amp board : Have to bend the legs of the 2 compensation caps if you are using Silver Mica caps or any other cap that wont fit otherwise.
No Thump Board : Have to rotate T1 180 degrees compared to silkscreen.
Supply Board : Have to use the other secondary for AC detection. Connector was added to the wrong secondary.
For this reason they are sold for a fair price.
2 x Amp Boards + 1 x No Thump Board + 1 x Supply Board is included in a set of boards
What I have left of V1 is :
2 pairs of Amp Boards left(maybe 3 if one can live with the soldermask being a little lumpy in some places)
9(or 11) No Thump Boards
10 Supply Boards
Price will be $30 USD for a set of V1 PCB's of which I'll be donating $3 USD to Diyaudio.com.
All boards are almost done being upgraded to V2(MKII) and I have fixed the few issues mentioned earlier as well as rearranging a few components, of which the Amp Boards will see the biggest change. One can see my Amp Board MKII in an earlier post. I'll be posting the final versions when they are done and I have the time for it.
Boards will be upgraded to MKII as needed. Once all boards are upgraded to MKII the price will increase to $40 USD for a set, of which I will be donating $5 USD to Diyaudio.com
As I mentioned in an older post, I'll be supplying schematics as well as a rudimentary BOM for all boards. So people will have to source their own components.
Old 22nd April 2012, 12:14 PM   #105
Attached is schematics and a rudimentary BOM for each of the current V1 boards.
Old 23rd April 2012, 07:43 PM   #106
There will be measurements tomorrow.
Old 24th April 2012, 12:59 AM   #107
qusp is offline qusp  Australia
qusp's Avatar
hmm ok still on the sidelines, but i'm about to clear a few things off the bench, so maybe, i'll see how the pocketbook feels, maybe i'll get the gen1 if theres any left on the weekend. either way its a cool design, maybe i'll throw some double die laterals at it ha
Old 24th April 2012, 09:05 AM   #108
I'm using a Stanford Research Systems SR780 2-channel network analyzer for the measurements.
The built in generator is worse than I expected, but the measurements should still give an idea of what the amp can do. Dynamic range of the SR780 FFT is limted to about 80-90 dB and the max frequency is 100 kHz, good enough for 1kHz but not ideal for 20kHz but it will have to do.
First 3 attached pictures are 1kHz generator output at 0.7Vpk, 1.4vpk, 2.8Vpk.
Last 3 attached pictures are 1kHz amp output at 1Vrms, 2Vrms, 4Vrms into a 33 Ohm dummy load.
Amplifier gain is X2
Generator distortion is 0.7Vpk/0.021% THD, 1.4Vpk/0.011% THD, 2.8Vpk/0.007% THD.
Amp distortion is 1Vrms/0.015% THD, 2Vrms/0.033% THD, 4Vrms/0.072% THD.
The somewhat high distortion of the generator as well as the limited dynamic range of the SR780 FFT puts a limited on how good I can get the measurements.
I do have access to an audio analyzer from Rohde & Schwarz and I might try using that some day, it might have better specifications.
Next up is 20kHz measurements.
Old 24th April 2012, 09:22 AM   #109
First 3 attached pictures are 20kHz generator output at 0.7Vpk, 1.4vpk, 2.8Vpk.
Last 3 attached pictures are 20kHz amp output at 1Vrms, 2Vrms, 4Vrms into a 33 Ohm dummy load.
Generator distortion is 0.7Vpk/0.035% THD, 1.4Vpk/0.0135% THD, 2.8Vpk/0.007% THD.
Amp distortion is 1Vrms/0.019% THD, 2Vrms/0.045% THD, 4Vrms/0.09% THD.
Old 24th April 2012, 10:28 AM   #110
After checking the specs of the R&S UPL Audio Analyzer I think I might be redoing the measurements some day. It only goes up to 110kHz, but has lower generator distortion, higher dynamic range and the noise floor is between -120 and -140.
Thor, an all discrete Lateral FET Headphone Amplifier.Hide this!Advertise here!
Discrete, Class A Lateral MosFET Headphone amp (not another follower buffer!) mnturner Headphone Systems 35 6th March 2012 07:52 PM
Discrete Single End TRUE Class A HeadPhone Amplifier lineup Headphone Systems 30 29th May 2009 09:44 PM
Mini Portable Headphone Amplifier, with Discrete Diamond Buffers cetoole Headphone Systems 3 30th May 2006 06:32 AM
