Thor, an all discrete Lateral FET Headphone Amplifier. - Page 5 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 4th March 2012, 04:28 PM   #41
Thor Supply CapMultiplier board in progress.
Some component values still not decided as well as the transistors in the capmultiplier but I have a few ideas.
The Cap Multiplier part of the supply circuit will be using a star ground to minimize hum.
File Type: png Thor-Supply-CapMultiplier-Schematic.png (51.0 KB, 392 views)
Old 4th March 2012, 05:21 PM   #42
Avro Arrow's Avatar
I might be interested in a pair of Mk2 amps boards depending on final price.
Old 4th March 2012, 07:42 PM   #43
Price would be $25 USD for a pair of MKII boards if I ever decide to get some boards made, not totally decided on that just yet.
Old 5th March 2012, 04:17 PM   #44
It is not a perfect star but I think it would work quite well anyway.
Old 5th March 2012, 06:19 PM   #45
Avro Arrow's Avatar
You should just make a polygon and fill that whole area up.
Thats more like a spider than a star
Old 5th March 2012, 06:23 PM   #46
Avro Arrow's Avatar
Here is an example of a dual rail board I did:
DIY Lab Power Supply
Old 5th March 2012, 06:56 PM   #47
Haha, yea, it looks like a spider.
However, I'm not sure a ground plane is a good idea for a cap multiplier.
What info I could find suggets a star ground layout for cap multipliers or atleast using something star-like.
But then again that was with nothing else than the cap multiplier connected after rectification, with LM317/LM337 as preregulation it might not be needed.
Old 5th March 2012, 07:03 PM   #48
Avro Arrow's Avatar
Maybe double the thickness of the center trace and end it at C13.
Polygon around the ground connections.
Try and get the other traces to come into the center trace closer together.
Good job on the project so far!
Old 6th March 2012, 05:04 PM   #49
Well, think I'm going with a ground plane.
Supply board should be done soon, just have to do a little more simulation and finding the correct transistors and resistor values.
Board should be ordered, mounted and tested some time in the beginning of april if all goes well.
Old 6th March 2012, 06:59 PM   #50
Transistors will be BC546/556 or BC547/557 preferably in C grade and BD135/136 or equivalent for the main pass transistor.
Gerber.
Discrete, Class A Lateral MosFET Headphone amp (not another follower buffer!) mnturner Headphone Systems 35 6th March 2012 07:52 PM
Discrete Single End TRUE Class A HeadPhone Amplifier lineup Headphone Systems 30 29th May 2009 09:44 PM
Mini Portable Headphone Amplifier, with Discrete Diamond Buffers cetoole Headphone Systems 3 30th May 2006 06:32 AM
Copyright 1999-2017 diyAudio
