Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 10th February 2012, 09:45 PM   #1
dirkwright's Avatar
Default My Head Phone Amp Project
Well, this is where I'm at with this project now. It's a 1U rack box from Hammond that I've modified. I'm not happy with Hammond's quality but not sure anyone else is better. Holes don't line up, stuff like that. Hate it. I added the shiny aluminum angle strips on each side since Hammond didn't see fit to provide support there. Thank God for rivet nuts.
Anyway, the boards are from Jim's Audio. His LME49600 headphone amp, with two of his Kubota power supply regulators are included. Input will be switch selectable between balanced and unbalanced, with Jensen input transformers and dual wire wound pots for volume control. The pots will be controlled by a single shaft using miniature plastic roller chain with sprockets. It's all pretty simple really. The square bar stock is for heat sinks from TO-220 power transistors on the Kubota boards. Normal heat sinks are too tall, as are normal electrolytic capacitors. I had to get special short ones to fit in the 1U rack space.
Old 12th February 2012, 12:57 PM   #2
dirkwright's Avatar
The amplifier board fully stuffed. The circuit has an LME49710 input and paralleled LME 49600 outputs per channel. I made some changes to the original circuit. I added a high frequency pole in the feedback loop as well as an RC low pass filter on the input.
Old 12th February 2012, 04:04 PM   #3
dirkwright's Avatar
The volume control. Since I couldn't find any 2 gange wire wound potentiometers, I came up with this arrangement for controlling 2 pots with one shaft. Thanks to McMaster Carr for the parts.
Old 12th February 2012, 04:49 PM   #4
LUUUUV IT!!!
Old 12th February 2012, 05:27 PM   #5
dirkwright's Avatar
Originally Posted by diy didi View Post
LUUUUV IT!!!
Thanks! I've never done this kind of project before. The chain is tight enough so that there's no slack and the two pots turn together. They have a linearity of +/-0.25% so if they are synchronized they should stay that way over the entire travel of the wiper.
Old 12th February 2012, 10:24 PM   #6
dirkwright's Avatar
OK, more progress today. One Kubota regulator is stuffed, and 4 heatsinks are filed and sanded. The heatsinks are 3/8" square bar stock. One screw through the TO220 device and two up from the bottom on the back side of the panel to hold it in place. Time to drill and tap some holes.
The front support for the volume control shaft is finished as well.
Stuffing of second Kubota regulator is ongoing.
Old 13th February 2012, 07:00 AM   #7
Stixx is offline Stixx  Germany
Stixx's Avatar
Good work there!
I like the use of the bar stock to connect to the bottom plate as one big heatsink...
Old 13th February 2012, 12:15 PM   #8
dirkwright's Avatar
Originally Posted by Stixx View Post
Good work there!
Thanks. The 1U rack height box is not tall enough for regular upright heatsinks so I had to come up with this solution. I need to buy the tap and drill though. It's going to be tricky I think drilling such small holes and then tapping them. I have a drill press now which makes this kind of work a lot easier.
Old 16th February 2012, 04:25 PM   #9
JustFJ is offline JustFJ  United States
why don't you try "the wire headphone amp" instead? their pcb are avaiable nowon, its better performance than this bad quality pcb
Old 16th February 2012, 04:41 PM   #10
gumleguf's Avatar
Nice work. Great sense of detail for sure... :-)
I want your head phone amp Ideas pk386 Solid State 9 8th May 2007 05:59 PM
27 head phone amp or.?? JandG Tubes / Valves 0 27th January 2007 05:42 PM
Head Phone AMp / Mic jleaman Everything Else 3 14th April 2006 04:48 PM
Ultimate Tube head phone amp. tube-lover Tubes / Valves 14 13th July 2005 04:25 PM
How to upgrade CDP head phone amp (NJM4580) DIAR Chip Amps 7 30th July 2004 01:23 AM
Page generated in 0.10872 seconds (76.83% PHP - 23.17% MySQL) with 11 queries
