Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 16th February 2012, 05:22 PM   #11
dirkwright's Avatar
Originally Posted by JustFJ View Post
why don't you try "the wire headphone amp" instead? their pcb are avaiable nowon, its better performance than this bad quality pcb
Of course, you realize it is rude to suggest something like this, don't you? Maybe you don't have proper manners. I was merely sharing my project, not asking for advice. If I was asking for advice, I would have clearly said so.
Unless you have seen this PCB in person I doubt you know what you're talking about. It is gold plated everywhere and the holes are through hole plated as well. This kind of chip amp is not rocket science anyway. Also, this circuit has two 49600's per channel, which is way overkill.
Exactly how is "the wire" a better PCB, or do you mean circuit?
Old 16th February 2012, 05:24 PM   #12
dirkwright's Avatar
Originally Posted by gumleguf View Post
Nice work. Great sense of detail for sure... :-)
Thanks! It does take a lot of concentration for me to do this, and yet I'm still not satisfied. I'm waiting on some stuff that I ordered, as well as the time to proceed further.
Old 18th February 2012, 10:02 PM   #13
dirkwright's Avatar
So, I had some time today and made some more progress on the enclosure. The rear panel is done. I installed the two Jensen transformers. I used a type of mu metal self stick thin metal under the transformers as a precaution. I put a larger sheet on the underside of the top panel (not pictured). The volume control is also done now. It works great. I need to lay out the front panel next, as well as drill and tap the 4 heatsinks. I finally got the 4-40 tap and drill set in the mail.
Thanks for the encouragement everyone!
Old 20th February 2012, 07:21 PM   #14
dirkwright's Avatar
I finished the front panel today. I had a serious problem because I pressed too hard on the drill press and the drill bit grabbed the panel and bent it up. I was very upset! It took me a while to hammer it back into something close to the way it was before. Now I know - go easy on the drill press and let the bit take it's time to cut through the metal.
It's very industrial looking, I know, but it's all I'm really capable of right now in my shop with the tools that I have.
Thanks for looking.
Old 20th February 2012, 11:20 PM   #15
ddietz is offline ddietz  United States
Looks great and nothing wrong with the industrial look.
As for the grabbing bit, always clamp anything to the press table that you can, but I don't see much in the photo to complain about!
Old 20th February 2012, 11:59 PM   #16
dirkwright's Avatar
Oh, it was clamped to a piece of wood on the drill press, and both were clamped to that. That's why it surprised me. The drill bit just bent it right up! The paint job they used is pretty tough since I pounded the crap out of it to make it reasonably straight again and the paint only has a few scratches on it.
Thanks for your comments.
Old 21st February 2012, 08:17 PM   #17
cfcubed is offline cfcubed  United States
cfcubed's Avatar
Originally Posted by dirkwright View Post
I added a high frequency pole in the feedback loop as well as an RC low pass filter on the input.
Would you mind elaborating on the above? Those ebay PCBs caught my eye & curious.
Nice looking project BTW... Combining the electrical & the mechanical (pot drive).
Old 21st February 2012, 08:35 PM   #18
dirkwright's Avatar
I replaced the 100K input resistor with a 220pF capacitor, and bypassed the 20kohm feedback resistor with a 10pF capacitor. Otherwise, this amplifier would be working out to radio frequencies. Since the input is connected to the wiper of a 10kohm potentiometer as a volume control, I didn't see the need for the 100k resistor. The LME49710 has an input bias current of a few nanoamps, so that tiny amount of DC through the pot hopefully won't make any difference.
The 10pF capacitor can be tack soldered on the backside of the board across the resistor.
I may not need the 220pF input capacitor since I'm using input transformers which limit input bandwidth anyway, but it's already soldered up now. I guess it's extra security.
Thanks!
Old 22nd February 2012, 07:15 AM   #19
Great job, looks really good. Love the dual pot solution!
Old 22nd February 2012, 02:52 PM   #20
dirkwright's Avatar
Thanks! I work on it when I have the time. There's always mistakes to either correct or accommodate... sigh.
I want your head phone amp Ideas pk386 Solid State 9 8th May 2007 05:59 PM
27 head phone amp or.?? JandG Tubes / Valves 0 27th January 2007 05:42 PM
Head Phone AMp / Mic jleaman Everything Else 3 14th April 2006 04:48 PM
Ultimate Tube head phone amp. tube-lover Tubes / Valves 14 13th July 2005 04:25 PM
How to upgrade CDP head phone amp (NJM4580) DIAR Chip Amps 7 30th July 2004 01:23 AM
Page generated in 0.13181 seconds (81.99% PHP - 18.01% MySQL) with 11 queries
