Headphone Systems Everything to do with Headphones
My Head Phone Amp Project
Old 25th February 2012, 11:50 PM   #21
dirkwright is offline dirkwright  United States
dirkwright's Avatar
More progress on the head phone amp. I've been busy wiring and soldering. The power supplies are providing power, the inputs are wired up, and heat sinks are drilled, tapped, and screwed in place. Absolutely no drama. I adjusted the power supplies for +/-15VDC and that was that. Nothing gets warm either. Hopefully this will turn out good. I'm using silver wire with teflon insulation for most of it.
Old 26th February 2012, 04:40 PM   #22
dirkwright's Avatar
OK, It's all wired up now, but I have a problem with it. It plays fine, but there's no bass. I don't understand that. There's no coupling caps in the circuit at all, so no RC filter. The transformers are supposed to be good to 10Hz. They are loaded by 10k ohm pots, just as required by Jensen. The DC offset on the output is about 1.5mV per channel, so I'm not sure that would have anything to do with it. I'll have to do some more investigating to figure this out. I used my old Sennheiser HD540's to listen.
Old 26th February 2012, 05:13 PM   #23
dirkwright's Avatar
This is the schematic for the amp. It's bone simple to me. I added the two small capacitors and in the process deleted a 100k resistor from input to ground. The input is directly connected to the wiper of the 10k pot. There is some scratching when ever I move the volume knob, but I guess that's normal with this arrangement.
Maybe I need to let it run for a while to get all those power supply capacitors formed? I dunno what's up... feeling like I'm
Old 26th February 2012, 05:36 PM   #24
qusp is offline qusp  Australia
qusp's Avatar
something is definitely up, because the wire, which although has superior layout should be similar, has some of the best bass ive ever heard with headphones
Old 26th February 2012, 07:06 PM   #25
dirkwright's Avatar
It's broke now. Only one channel is working. I'll investigate when I have time. I suspect the power supply. I'm planning on changing the input circuit to include a DC blocking capacitor.
Old 26th February 2012, 10:33 PM   #26
dirkwright's Avatar
I have a theory that I bought the wrong power transformers. I got secondaries with 2x15VAC, so since I don't know the dropout for the regulator, I may not be able to get +/-15VDC out of them. I turned the regulators down to +/-14VDC but haven't had time to test them. I measured about 4 volts across the series power transistors in the regulators after dropping the outputs by 1 volt.
Old 27th February 2012, 08:39 AM   #27
andrewscott is offline andrewscott  Australia
Details you have disscuss here are great and helpful ..It's going to be tricky and it helps to do work a lot easier.
Old 28th February 2012, 01:14 AM   #28
dirkwright's Avatar
Thanks for the support.
I figured out the problem. It was not the power supplies after all. I wired the potentiometers incorrectly. Then I found that I had way too much gain. So, I swapped the 20k resistor for a 1k. Still a lot of gain, but I guess the HD580's are fairly sensitive. The amp does sound really good now.
Old 28th February 2012, 04:47 PM   #29
Redshift187 is offline Redshift187  Canada
You should have the input resistor to ground, because if your pot somehow loses connection to ground, you could have maximum input level and damage something.
Tyler
Old 28th February 2012, 07:27 PM   #30
dirkwright's Avatar
Yeah, thanks. I was thinking of putting some kind of high value resistor there. I'm just glad I got it working now.
My Head Phone Amp ProjectHide this!Advertise here!
I want your head phone amp Ideas pk386 Solid State 9 8th May 2007 06:59 PM
27 head phone amp or.?? JandG Tubes / Valves 0 27th January 2007 06:42 PM
Head Phone AMp / Mic jleaman Everything Else 3 14th April 2006 05:48 PM
Ultimate Tube head phone amp. tube-lover Tubes / Valves 14 13th July 2005 05:25 PM
How to upgrade CDP head phone amp (NJM4580) DIAR Chip Amps 7 30th July 2004 02:23 AM
Copyright ©1999-2017 diyAudio
