Objective 2 Amp Popping Noise - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 10th February 2012, 12:09 PM   #1
Default Objective 2 Amp Popping Noise
I have a friend who's Objective 2 amp pops when he turns it off. I thought it was normal when it did it with mine. Can anyone suspect what this may be? I am pretty positive it is not the mosfets. How would I go about fixing this? I just thought his volume was too high when he turned it on/off. What else could it be?
Old 10th February 2012, 03:52 PM   #2
GTrenchev's Avatar
Can you measure the transient?I mean,the voltage of the DC spike?If it's less than 50mv,it's fine.
Old 11th February 2012, 02:35 PM   #3
Which tests do I need to do that?
Old 12th February 2012, 10:54 AM   #4
GTrenchev's Avatar
Use a DMM.
Popping noise from sub?Could it be the amp? tcsounds3hp18 Car Audio 0 2nd June 2011 04:34 AM
Speakers popping and static noise at all volume levels PPI Amp duderino201 Car Audio 21 8th May 2010 09:19 PM
Amp causing popping noise? guitarguy12387 Car Audio 7 15th April 2008 01:58 AM
Popping Noise = Clipping ? liggs17 Tubes / Valves 5 28th November 2006 07:16 PM
Question about popping Noise Derrick Tubes / Valves 5 27th February 2004 10:34 PM
Copyright 1999-2017 diyAudio
