| Headphone Systems Everything to do with Headphones |
#11 |
The schematics in the the past threads showed the use of TWO Power supplies to drive the amp. No doubt a turn off to the DIYer. Do we need two power supplies?. Absolutely not. The past shematics also showed using a regulated power supply. Another turn-off! I had it at hand and it was convenient to use. Fortunately we do not need a regulated power supply to drive the amp. We only need one unregulated [dual] power supply per channel in the range of +/-10 VDC to +/-20 VDC. Figure 1 in the attached PDF Headphone 006 shows the [even] simpler schematic of the transconductance amp. It is mostly like that shown in the previous thread less the now-obsolete +/- 6 VDC supply. The schematic also shows the use of one dual +/- 15VDC power supply. The schematic of this common power supply is shown in Figure 2. It is comprised of a power transformer (12Vac secondary plus a center tap), a bridge rectifier and 2 filter capacitors (4700 microfarad each). Note its the battery model which I used in Figure 1. The CENTER TAP of the transformer's secondary joins the common junction of the filter capacitors, and most importantly it is the OUTPUT PORT Vo and not the customary ground.
In operation, the variation in the output voltage Vo is a trivial disturbance to the working of the JFET constant current sources (CCSs). The +/- 200 mV peak to peak level of Vo across the headphone [for my comfortable listening] is less than 1% voltage variation across the CCSs; i.e. (0.2V signal divided by 30 V power supply times 100 = 0.7%). Also, the value of the current passing through the JFETs is quite stable over a wide range of power supplies. Thus the JFETs resist the voltage variations in Vo and present themselves to the power supply as impedances of high value. Food for thought. Suppose I use two resistors (5.6 K each instead of the JFET contant current sources. One resistor is connected to the +15 V and the other to -15 V. The current passing through them is 30 V divided by 11.2 K = ~2.7 mA which also flows through the diodes to bias the output transistors. In operation the situation is quite different from the one I described above.
#12 |
I have an omission in Figure 2 of the previous thread. Figure 2 shows the schematic of a common power supply. The secondary of the power transformer equal to 12.6 Vac plus a center tap should give ~+/-18.5 VDC instead of the quoted +/-15 VDC. I used a variac or autotransformer on the primary of the power supply transformer to tweak the output voltage to +/-15 VDC.
#13 |
What value does this headphone transconductance amplifier or [attenuator; see below for more discussion] bring to the table? How does it compare with other voltage source amplifiers on several issues?
#14 |
As I made the device simpler [in design], hum from the power supply crept in the output. Hum became noticeable and/or objectionable. So, power to the device is now enabled by using rechargeable batteries; which rendered it portable if that is an important attribute to the DIYer. The attached PDF Headphone 007 shows two schematics. The first is for the active circuitry and the second details the circuit which can be used to recharge the power supply batteries when the device is idle. Let us focus on the first schematic. Note the following:
The battery-recharging circuit is straight forward. It will be useful for small 12 V Pb-acid batteries. Two commercial or home-made rechargers are needed for both channels with one recharger for each power supply rail. A [single pole triple throw] switch is used for each channel. One position recharges the batteries for both power supply rails and both audio channels. The opposite position of the switch disables both rechargers completely and simultaneously turns on power to both channels of the headphone device. It will be a useful tool to have and or build so to use instead of the classical power line supply. The sound of the device (one channel driving both headphones), was detailed and tonally balanced. Understandably, there was no 60 Hz hum in the headphones, but a mere 2 milliVolt peak to peak broad band noise at the ouptut port as seen on the scope. I am inclined to "box up" two channels. Pictures of my progress will be forthcoming. |
#15 |
The two attachments did not upload in the previous thread. Here they are.
#16 |
Above you wrote that you smoothed out the sharp edges of the impedance plot due to measurement inaccuracies. Are you sure those are measurement inaccuracies? Afaik, the impedance is not as smooth and with a transconductance amp this will cause similar "inaccuracies / sharp edges" in the frequency response.
Dunno if you have the equipment needed for this but I'd love to see a sweep that you recorded from your Grados powered by this amp. |
#17 |
I agree with your analysis. Your recommendation will be the ideal experiment. I have a function generator with a digital readout and an oscilloscope. I dialed the desired frequency and then measured the attendant output voltage on the scope's 0.1 V/division scale. I utilized 4 divisions each of which contains 4 subdivisions. The measurement inaccuracy was in my reading the scope's subdivisions. Was it 3.6 or 3.5 subdivisions? Please go to the website www.firstwatt.com. Mr Pass has 2 articles which discuss transconductance (current source) amps and their use to drive speakers. He showed graphs of your proposed experiment; except on high end loudspeaker drivers. Regards
| LM1875 as transconductance amp for Fostex | m@ | Chip Amps | 22 | 6th February 2012 11:48 AM |
| Power Transconductance Amp with Tubes, How? | CLS | Tubes / Valves | 26 | 14th January 2008 05:35 AM |
| parallel EL84 transconductance amp | nesha | Tubes / Valves | 6 | 11th November 2007 08:51 AM |
| ZV9 as transconductance amp | we416b | Pass Labs | 15 | 4th April 2006 09:52 AM |
| Complementary Zen V.5 Transconductance Amp | jbfitz | Pass Labs | 1 | 15th November 2005 08:27 PM |
| Page generated in 0.13658 seconds (84.59% PHP - 15.41% MySQL) with 11 queries |
