Headphone Cable - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 4th January 2012, 06:17 AM   #11
How on earth is the shield to be removed? I thought they were woven like a chinese finger trap. That's why I just recommended leaving it and not connecting it. It's a short run. I wouldn't expect problems until beyond 2m. Even then, I might expect something measurable but not audible in a blind test.
Old 4th January 2012, 11:53 AM   #12
DF96 is offline DF96  England
I wouldn't start from here. If you want a shield, use a shielded cable. If you don't want a shield, use an unshielded cable.
Old 4th January 2012, 02:20 PM   #13
Finding an unshielded cable with 4 leads twisted that is flexible and has excellent audio band performance is proving difficult.
Do you have a source or recommendation?
Old 4th January 2012, 04:07 PM   #14
No, sorry.
Old 4th January 2012, 04:59 PM   #15
Steve Eddy's Avatar
Canare's 46S fits that bill if you don't mind the somewhat largish 20 gauge leads.
se
The Audio Guild
Old 4th January 2012, 08:45 PM   #16
Speedskater's Avatar
Not that I think a good headphone amplifier needs a shielded cable. The headphones themselves sure don't! But in any case a shield does not need to be connected at both ends if it's only job is a shield.
Kevin
Old 7th January 2012, 06:47 AM   #17
qusp is offline qusp  Australia
qusp's Avatar
yeah it kinda does and if not it would be useful if it actually shielded something more than itself ie the voice coil and it should at the least have its own connection to chassis ground, which phono plugs do not have. As a result it simply shunts the noise along the cable length, leaving out the headphones; to signal ground.....
in answer to those asking about unshielded cable, any reasonable quality hookup wire will do, how hard is it to twist a couple of pairs 6' long? its actually not that hard to remove the shield from ready made cables either, just a pair of tin snips will do nicely; also UTP isnt hard to find
Old 7th January 2012, 11:34 AM   #18
wwenze is offline wwenze  Singapore
Hmm... CAT 6 cables...
Old 7th January 2012, 02:48 PM   #19
qusp's Avatar
yeah thats the type of thing i meant by UTP, but probably not entirely practical, not the most flexible cable going
Old 10th January 2012, 09:28 PM   #20
Wolfsin is offline Wolfsin  United States
Default Sacrifice is not always bad
After much too much wiring in many too many wayz (accompanied by rolls of laughter and eyeballs among readers) I settled on a willfully sacrificed length of dual twisted pair Rockford Fosgate cable (no shield, no kidding)!
Building balanced headphone cables?
'gardz, Dick
problem with a headphone cable nagienozdrza Headphone Systems 0 21st May 2011 10:23 AM
soldering headphone cable meaghers Headphone Systems 4 21st November 2006 12:48 AM
Re-wiring a tonearm with headphone cable. mattjk Headphone Systems 1 2nd March 2005 01:40 PM
Headphone cable crosstalk - how to avoid? halcyon Headphone Systems 11 15th March 2003 07:02 PM
Copyright 1999-2017 diyAudio
