my ck2iii my ck2iii - Page 2 - diyAudio
Headphone Systems Everything to do with Headphones
my ck2iii
my ck2iii
Old 17th December 2011, 05:31 AM   #11
qusp is offline qusp  Australia
qusp's Avatar
yeah ive seen them before there, but just like the cannon and amphenols its only useful if you have a set that needs a couple pieces or a spare, because they never have a full set of everything, as in 2 female or a male and female panel mount with 2 matching cable connectors, so a 4 connector set and thats the minimum you need unles its just for a single headphone cable and you only have one headphone, because most are old models
Old 22nd December 2011, 09:44 PM   #12
routhun is offline routhun  United States
How does it sound? internal pics?
Thanks,
Routhu
routhun
Old 25th December 2011, 03:20 AM   #13
conchimnon is offline conchimnon  Viet Nam
If i used bc550b/560b and opa LME49720HA, have any problem????
Old 29th December 2011, 11:19 AM   #14
jtktam is offline jtktam  Canada
my ck2iii
if you have the time to wait, start to stockpile the different parts and you should come up with a set.. i have a full metal set that is laying around if you want to buy it from me
Thanks,
Routhu
I have internal pics.. I will post when I get home in a few days.. it sounds very nice, it is very sensitive to noise I find..
you would have to check with amb forum..
-joe
Old 2nd January 2012, 08:01 PM   #15
Default Finished my Ck3 during holidays
Here is my CK3 finished during these holidays. Output stage is not BJT but with IRFZ24n and IRF9Z34n, mods are suggested by Ti Kan for this MOSFET output stage. Case is from eBay, seller is along1986090. Case is great for the price, esp the front panel around 1/4inch thick.
Sound is amazing from my AudioTechnica ATH-M40fs. I also used this as a preamp with 100+100 ohm resistor divider in the output to reduce the gain for amplifier hookup. It is greater even as a preamp driving my Luxman M-4000 amp. Cannot stop listening to this setup, even my wife also certifies this.
These pictures are from my phone, will post better pictures later.
routhun
Old 2nd January 2012, 09:15 PM   #16
my ck2iii
hi.. can you tell me more about the headphone jack pcb? is that a headphone protection circuit?
-joe
Old 2nd January 2012, 09:36 PM   #17
Hi Joe,
Yes it is the protection circuit, since this headphone amp is directly coupled I used this circuit to save my headphones in case the circuit malfunctions. I got this one from the same vendor. This circuit works for 9v I need to recompute some resistors to make it work with my transformer which 16v.
Here is the link
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
routhun
Old 8th January 2012, 12:35 AM   #18
Default Pictures with better resolution
Enjoy,
Routhun
routhun
Old 8th January 2012, 06:28 AM   #19
regal is offline regal  United States
Originally Posted by jtktam View Post
amphenols
they are not cheap and only come in two major configs.. 3+1 and 6+1 (they always mark one pin as ground, but that pins is the same size as the other ones, so you can use it like any other pin)
the 3+1 is screwed based and 6+1 is solder based..
I use both and they are built the same way, have the same cut out.. so I don't have to worry about having two different templates
-joe
For a budget PS-amp umbilical these SRCN series by JAE from digikey have been reliable for me, my cord making skill is sloppy but you get the idea:
my ck2iiiHide this!Advertise here!
FS: CK2iii with outboard power supply jtktam Swap Meet 0 20th November 2011 02:43 PM
FS: CK2III - Cavalli Kan Kumisa..Headphone amplifier sachi Swap Meet 0 18th March 2009 06:38 AM
CK2III headphone amp problem then_dude Headphone Systems 9 21st November 2007 11:52 PM
Copyright ©1999-2017 diyAudio
