Will HD580 headband cushion fit HD650? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 12th December 2011, 02:41 PM   #1
pixpop is offline pixpop  United States
pixpop's Avatar
Send a message via Skype™ to pixpop
Question Will HD580 headband cushion fit HD650?
I can't seem to locate any replacement headband cushions for the HD650.
Does anyone here know if the headband cushion for the HD580 (or any other headband) can be used as a replacement for the HD650 one?
Neil
Old 26th January 2012, 08:09 PM   #2
pixpop's Avatar
OK, OK, I know you've all been waiting with bated breath for the answer to this. Well, here it is.
Yes.
For the curious, here's what you need to order:
HD580, 600 Ear cushions: Part number 050635
HD580 Headband cushion: Part number 052715
Here's a video that explains how to replace the headband cushion:
Sennheiser HD-580 Headband pad repair
The ear cushions are just a press fit. Tug on them, and they pop out easily.
I was able to find both these items on the Sennheiser website.
Old 27th January 2012, 01:26 AM   #3
So the HD600 and HD650 are in fact compatible as has been assumed. Good to know.
Old 28th January 2012, 04:40 PM   #4
JFTR, HD650 headband pads are part #088597. I'd prefer these if you're not planning on cutting some foam and taping it on yourself (the pad area remains quite narrow regardless of which stock pad you use, though I think the '650 pad makes the most of it).
And yes, '600s and '650s are mechanically compatible. Pads, drivers and cables also fit the old HD5x5 series that was around in the '90s.
F/S Sennheiser HD580 Headphones rubicon Swap Meet 6 6th December 2010 03:52 PM
which type of rubber cushion under transformers? vax9000 Tubes / Valves 18 3rd May 2008 09:44 AM
headband magnifier for SMD work gychang Parts 4 1st November 2007 03:28 PM
Blown surround foam cushion angers Subwoofers 4 27th June 2006 04:54 PM
So I have some HD580 headphones, need a amp AJ Bertelson Solid State 2 24th February 2003 10:29 PM
Copyright 1999-2017 diyAudio
