Headphone Systems Everything to do with Headphones
"The Burst" DIY Headphone Amplifier
Old 5th November 2011, 07:25 PM   #11
sgrossklass is offline sgrossklass  Germany
Originally Posted by afternath View Post
About resistors values in a op amp circuit, in general lowering values will lowering noise so what is the disadvantage of it?
Output loading and power dissipation mostly.
Old 25th November 2011, 03:46 AM   #12
gootee is offline gootee  United States
These guys are all giving you really-excellent and complete advice, and you should implement ALL of it.
However, before doing anything else, you must be sure to connect a 0.1 uF X7R ceramic capacitor from RIGHT AT each opamp power pin to ground, and parallel each of those with a 10 uF electrolytic that can be a few millimeters farther away from each power pin.
And you must put at least 100uF electrolytic in parallel with (each of) C7, C8, C16, and C17.
NOTE, too, that R19 and R20, as well as R16 and R9, should be connected VERY close to the opamp pins.
Old 26th December 2011, 09:27 AM   #13
rho is offline rho  Belgium
Have you made any progress on this?
Old 26th December 2011, 10:22 AM   #14
afternath is offline afternath  France
afternath's Avatar
Thanks a lot for advices, but i will not be able to implement all of them because I used one tiny stripboard for left and right vol amp/pushpull circuit, so there is not enough space...
Otherwise, this amp sounds great with my AKG K702, clean sound and no problems at all.
Old 6th April 2013, 12:07 PM   #15
xslavic is offline xslavic  Moldova
Default Volume control pot buffer highs cut
hey aftermath does your volume control buffer works ok,no highs cut?
would you recommend this instead ?
Old 6th April 2013, 04:36 PM   #16
afternath's Avatar
I used a 10k ALPS Audio Potentiometer for volume control and it works perfectly, very smooth and no scratch sounds.
The frequency response of my preamp is absolutely flat from 20Hz to 20kHz and above.
"The Burst" DIY Headphone AmplifierHide this!Advertise here!
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's opc Headphone Systems 2608 9th September 2017 08:37 PM
Codename "Tapyrus", my ongoing DIY headphone amp fbx Tubes / Valves 28 2nd October 2011 08:03 PM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 08:47 AM
Copyright ©1999-2017 diyAudio
