| Headphone Systems Everything to do with Headphones |
#71 |
Fortunately for me I haven't decided or bought the suggested B2-080 box so I will have extra room for accommodating the bass boost switch
![]() On the other hand, may be a third DPDT Pushbutton Switch like the one listed in the BOM for the gain boost might fit the B2-080 box, and help to solve the clearance issue for the chaps like jschristian44 who are dealing with this mod...it seems to be under 0.4" and it could be placed over the original gain switch.... what I can see from the pics of the front plate there is enough room ¿? |
#72 |
BlueRob: Good thoughts, but that slider switch is PC board mount style. The switch for the boost would have to be panel mount with a threaded collar and nut.
One thing to watch out for with the B3-080 case - the B2-080 front panels won't fit (not tall enough). There were some B3 panels made during a group buy a few months ago, but I'm not sure if anyone is selling B3 front panels now. The case comes with blank panels though, so you could always drill it yourself if you have a drill press! The measurements RocketScientist gives on his blog for the panel should work as long as you measure from bottom-up.
#73 | |
-coolhead |
#74 |
My Bass Boost mod will have to wait....looks like I got a faulty PCB, it seems that the path between R16 and U1 is faulty.Frustrated! |
#75 |
AGDR is there any chance you update and upload the 02 schematic with the 3db bass boost including the switch?
I´m having trouble digesting the overall layout to proceed with this mod. Thanks in advance! Rob. |
#76 |
#77 |
Could you tell me if your amp has better battery life on you 9.6v batteries? If not, did they change performance in any other way?
#78 | |
The 9.6V cell just gives 9.6V - 8.4V = 1.2V, another single NiMH cell's worth, of voltage swing on each rail, raising the voltage level at which clipping would occur in the two O2 amp stages. For low impedance headphones (32R, 80R), requiring only small voltage swings, either battery voltage is probably fine. But with high impedance (600R, 250R) and low sensitivity cans that need large voltage swings, the extra 1.2V may make all the difference. Even at full charge of around 10.5Vdc that 9.6V(nominal) cell is still 1.5V below the AC rails of +/-12Vdc, which themselves are marginal for some 600R low efficiency cans. But... that is all just theory. It would be interesting to hear from anyone using the blue "8.4V" Tenergy cells who have actually experienced clipping with the O2 using high impedance headphones. Also anyone who has done some real-world battery run time tests on the O2.
#79 |
Considering the O2 is "transparent" is power output the only thing you are going to gain by using higher V batteries? Will it improve the sound at all in any way? I am waiting for some parts for mine so I have no experience with the amp yet.
#80 |
Available gain and/or output voltage swing, yes. I'm not so sure about increased power output.
As agdr stated, that bit of extra voltage swing could possibly improve the sound from certain exotic cans.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
| Reduced diode switching by placing a cap across | Goetz | Power Supplies | 10 | 19th December 2011 12:38 AM |
| DC blocker diode/cap orientation | Glen B | Solid State | 4 | 22nd August 2011 05:46 PM |
| Mounting a small signal diode on heatsink - need suggestion | IG81 | Solid State | 14 | 3rd November 2009 04:12 PM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| Diode Heatsink | dmk | Tubes / Valves | 8 | 9th September 2007 04:03 PM |
