HA-PRO Single-ended  MOSFET HA-PRO Single-ended MOSFET - Page 2 - diyAudio
Headphone Systems Everything to do with Headphones
Old 27th April 2013, 04:11 PM   #11
istvan is offline istvan  Hungary
This new PCB looks much better, than previous one. What about soud? What is your impression? Who else try it? A/B tests or other comparison as reference?
BR, Istvan
Old 29th April 2013, 04:51 PM   #12
Telstar is offline Telstar  Italy
Definitely.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 29th April 2013, 05:52 PM   #13
Originally Posted by southernoise View Post
What transformer VA rating should I use for this kit?
How largr the Heatsink? Thanks.
The transformer should be 20W, and the dissipation/chanels mosfets (Q3&Q6, respectively Q8&Q11) is approx 3W/chanel.
BR, Istvan
Old 19th August 2013, 02:38 PM   #14
ljm_ljm is offline ljm_ljm  China
AC24V voltage is more important
OR AC12-0-12 Series connection
Old 29th August 2013, 05:42 AM   #15
stillstone is offline stillstone  China
hi Ljm , now u learned good English languish, times changes man.
Old 28th February 2014, 11:40 AM   #16
xslavic is offline xslavic  Moldova
should we bypass r19,r34 with 170uF capacitor ?
Old 28th February 2014, 03:45 PM   #17
00940 is offline 00940  Belgium
It really isn't a good idea to use 16V rated caps at the output. If the top mosfet fails open... Good practice for output caps is to use at least a voltage rating equal to the unregulated rail.
Ben.
Old 18th March 2014, 08:05 AM   #18
shouldnt R16 R31 be removed ? it will form RC filter with headphone impedance -and you cant compensate for cable capacitance this way.
i also used line filter as no filtering device after 7824 ,next time use a low noise transistor please +1 irf610 wont be much of an expense
Old 18th March 2014, 10:55 PM   #19
MagnumOpus is offline MagnumOpus  Norway
Fifty bucks including a case on fleabay. If I can find a cheap enough xformer I might just give it a go..
"Simplicity is the key to brilliance"
Old 14th May 2014, 02:46 PM   #20
another LJM pcb that doesnt work
can you please post schematics for last version of hapro irf610 classA
HA-PRO Single-ended  MOSFETHide this!Advertise here!
Single Ended mosfet problems Carlp Solid State 9 24th January 2011 12:38 PM
Single-ended mosfet-tube follower KlausB Solid State 44 17th May 2009 06:28 PM
Tube-Mosfet Single-Ended Amplifier! Matthewong Solid State 15 2nd October 2008 05:13 AM
single ended mosfet amp KlausB Solid State 11 26th February 2004 07:47 PM
Copyright ©1999-2017 diyAudio
