DPDT switch to disconnect headphones on power down? - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 14th September 2011, 05:28 PM   #1
Default DPDT switch to disconnect headphones on power down?
I have this idea about using a DPDT break-before-make toggle, not sure how well it would work... I don't think I've seen this done anywhere.
Since headphones return at the TRS jack with a common ground, would it be beneficial to connect the common pin to a DPDT power switch so that when the amp powers off, the headphones are then seen as open circuit and any imbalance in the power rail / output cap discharge would have no effect on the phones, while also eliminating the power-down pop? This would however do nothing for power up pop though..
The switch should have sufficient current handling and be low resistance, I suppose this is not an issue with headphones. If the power switch needs to disconnect 2 rails then a 3PDT switch may be employed.
Old 14th September 2011, 06:08 PM   #2
No, The leakage current from the AC power circuit would leak into the headphone circuit. Headphone jacks normally have current limiting resistors to prevent any damge due to transients.
Old 14th September 2011, 06:15 PM   #3
As regard to AC, this wouldn't be an issue if the power switch is cutting DC then?
Old 14th September 2011, 06:40 PM   #4
Less than 24 volts DC would be okay.
Old 14th September 2011, 06:49 PM   #5
That's rather interesting... if the DC supply is sufficiently clean there would be little alternating field within the switch to induce audible current on a nearby switch.
Are you suggesting that having 24VDC+ close by might induce DC offset?
I find this a bit challenging to think of considering how low impedance loads headphones tend to be, but what do I know...
Old 14th September 2011, 08:10 PM   #6
24 Volts is the limit set by safety codes.
Old 14th September 2011, 08:31 PM   #7
Thanks for clearing that up!
http://www.nkkswitches.com/pdf/MtogglesBushing.pdf
The switch in question is rated for 30VDC, but I guess it's better to not run it to its rating.
DPDT switch problem supermoose2011 Instruments and Amps 4 17th June 2011 08:51 AM
Using a dpdt switch as on/off? haakok Parts 6 3rd May 2009 06:55 PM
Looking for dpdt switch jeff5x0 Parts 2 28th February 2006 09:35 PM
Need help wiring DPDT switch Static1 Parts 4 14th October 2003 11:25 PM
HVDC DPDT Switch Jack Thomas Parts 4 31st July 2002 01:16 AM
Copyright 1999-2017 diyAudio
