RJM Audio Sapphire Desktop Headphone Amplifier - Page 9 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 8th June 2012, 09:57 PM   #81
sandbasser's Avatar
rjm -
Interesting...
Is there anything special about the TDK ceramics you call out in your blog post??? I have quite a few Kemet ceramics (both C0G and X7R varieties); they should be ok shouldn't they???
- Ray
Old 9th June 2012, 12:10 AM   #82
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
No, there is nothing special about them, they are standard x7r or the like, multilayer ceramics and anything similar should work just as well.
RJM Audio (phonoclone.com / G+)
Old 21st June 2012, 01:46 AM   #83
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
In order of good-better-best: X7R is not so good. COG is better and NPO is best as ceramics go. -RNM
Old 26th June 2012, 01:21 AM   #84
Richard Murdey
rjm's Avatar
In order of increasing temperature stability ... and price.
Did you or anyone ever test whether this was actually an important (read: audible) feature when using the capacitor in bypass (not signal coupling) applications? I have vague recollections of seeing hysteresis loops on scope traces in an article I read years ago. Was that yours?
Old 26th June 2012, 02:40 AM   #85
raul_77 is offline raul_77  Europe
The work of Cyril Bateman. X7R, X5R, Z5U, Y5V distord very bad, only NPO-COG are adecuated for audio:
Capacitor Sounds, Speaker Cables and Crossover Inductors.
Old 26th June 2012, 04:02 AM   #86
Richard Murdey
rjm's Avatar
I guess what I'm asking is has anyone swapped X7R for NPO as bypass caps for an opamp and claimed to hear a significant improvement?
Old 26th June 2012, 04:48 PM   #87
RNMarsh's Avatar
Many, many people and audio equipment manufacturers have heard changes reported over past several decades when bypassing on the power supply using differect cap dielectrics. I suspect it depends a lot on the circuits PSRR just how much affect it has. Many tube circuits seem to be more affected than IC's.
Old 26th June 2012, 10:18 PM   #88
jcx is offline jcx  United States
I recall one such audio bypass cap "tasting" test rated X7R bypass "better sounding" - at least while Blinding was in place
% distortion of the PS ripple shouldn't have much effect, only a very high Z PS ( == bad ) would let your circuit "see" bypass C dielectric effects at audio
Old 27th June 2012, 07:47 AM   #89
simonov is offline simonov  Bulgaria
simonov's Avatar
SE tube designs are not the usual place where one can find small smd capacitors
However I'm wandering. How is it possible to hear a difference in an opamp circuit that has over 100dB of PSRR? For PS bypass caps ner the IC pins I use X7R's and I'm perfectly happy with that. When I need a smd cap which is in the signal path I go straight to the film caps. Those are a bit expensive and bulky (most in 1206 or larger package). For the record - I don't have the golden years disease
Just my 5 cents. Regards, Venci.
Old 7th July 2012, 05:42 PM   #90
RNMarsh's Avatar
It probably makes little difference... I havent listened, myself to that IC app you are describing. If it works for you, what else matters? I am saying - for readers here under a wide variety of conditions and circuits -that if you dont know what to do or what to use, go with the better caps rank listed to assure yourself of the best results.
RJM Audio Sapphire Headphone Amplifier rev14a1 kit rjm Group Buys 14 2nd September 2016 11:23 PM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 7th September 2011 11:59 PM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 06:55 PM
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 04:23 PM
FS: DIY Cavalli Audio Embedded Hybrid Headphone Amplifier sachi Swap Meet 4 19th May 2010 09:43 PM
Copyright 1999-2017 diyAudio
