Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 24th February 2014, 02:31 PM   #201
Bibio is offline Bibio  Scotland
Bibio's Avatar
ooopppss i just noticed i got the components the wrong way round but you know what i mean.
Old 24th February 2014, 11:15 PM   #202
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Originally Posted by Bibio View Post
Richard, could i use the B2 pad and the -out pad on the 14s1 boards to fit a zobel filter?
like this:
Sure, the capacitor and resistor are in series so the order doesn't matter, and it can go between the OUT+ signal at any point back to the nominal output return, (OUT-, COM).
I remember I strung mine between the pins of the headphone jack at one point.
note: revision 2.0 boards have pads for the optional Zobel filter.
RJM Audio (phonoclone.com / G+)
Old 25th February 2014, 11:39 AM   #203
Bibio's Avatar
thanks Richard.
Old 1st March 2014, 08:34 PM   #204
udailey is offline udailey  United States
Default Single Sided board
I used Sprint Layout 6.0 to layout a single sided board. I made a few changes. On board rectifiers are surface mount round barrel type. I think MELF? Anyway, I doubled initial smoothing caps and added a few ceramic caps.
I left out the zobel.
I tried to do it without jumpers but I have two. Otherwise I couldnt find a way to keep ground from being interrupted.
I use large oval pads because they are easier to solder and I always make smt pads larger than they should be for easy soldering.
R5 and R6 are extra long almost like jumpers to reach from the top of the board to the bottom of the 4 transistors.
An MKP4 might not fit by about 2.5mm. I put the .lay file in my post so you can fit in a larger cap if you like.
Also the whole thing had to fit to 3" by 6" to fit my copper clad boards so things look pretty cramped in some areas but I'm looking forward to building it. Dont assume that this works instantly. If you want to use my file then please double check it against the schematic. I might build it this week if I find all the parts. Not sure if I have all the BD140/BD139. I think just 4 of each. So I'll have to order before I will know if this thing works great or not.
The yellow lines are jumpers from the rails. This was just for me to listen to this headamp so perfection is not included on this layout. Its free though
I'd like to get this working and then try it with a simple BF862 pre vs the opamp. Of course you know I love LDRs so I need to try it with LDRs at some point also.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 1st March 2014, 10:20 PM   #205
Richard Murdey
rjm's Avatar
As you've found, a single-sided board necessitates a jumper or two.
By the way, the capacitor banks of 3x1000 uF and 3x100 uF shown on the schematic are not set in stone. It's because I keep a stock of these values common to all my projects, so if I want 3300 uF, for example, I'll just use three 1000 uF in parallel. If I want 2200 uF, I'll use two 1000 uF. Feel free to change the arrangement as you like, a single 3300 uF (or a bit more, or less) will be fine for the filter capacitance before the regulator.
Richard
Old 16th March 2014, 12:32 AM   #206
Richard Murdey
rjm's Avatar
Replaced my first set of 2.0f boards with a new set. This time, I left out the Zobel filter and ceramic bypass caps. C1 reduced from 0.47 to 0.33 uF (Multicap PPFXS). Resistors are PRP metal film, Takman carbon film, and Kayama carbon comp. IC1 is OPA134. Gain is set at 27 dB with R4=22k.
Still breaking in, but it sounds nice. A tad dry, faster than I remember, very nimble actually. I don't think there is any disadvantage to leaving out the bypass caps, none that I can hear at present but I'll put them in later to double check.
Photo note: Nikon D600, Tamrom SP 90mm F2.8 macro 272E
Old 24th March 2014, 11:54 PM   #207
Bibio's Avatar
goodbye buzz hello silence :-)
finally got rid of those nasty nasty RS toroids and installed a custom built Toroidy 300-4x12 and it's completely silent.
Old 25th March 2014, 12:14 AM   #208
Have you got any pictures?
"Simplicity is the key to brilliance"
Old 25th March 2014, 01:50 AM   #209
Bibio's Avatar
just charging the camera battery.
it might be me but i could swear that the noise floor has dropped and everything is sounding a bit smoother. if i had one comment i would say that it has lost a very small amount of soundstage to which i actually like as its brought everything a tiny bit more to the middle of my head. but it could be a placebo.
Old 25th March 2014, 02:58 AM   #210
Bibio's Avatar
front of cases
Amp internals
power supply internals
ignore all the squintness i'm crap at taking pics everything is straight.
RJM Audio Sapphire Headphone Amplifier rev14a1 kit rjm Group Buys 12 12th December 2011 07:43 AM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 7th September 2011 11:59 PM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 06:55 PM
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 04:23 PM
FS: DIY Cavalli Audio Embedded Hybrid Headphone Amplifier sachi Swap Meet 4 19th May 2010 09:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
