Headphone Systems Everything to do with Headphones
RJM Audio Sapphire Desktop Headphone Amplifier
Old 17th September 2011, 07:19 AM   #11
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
R14 = 33 R would do the trick. The penalty you pay is a small reduction in maximum output power, and a relatively large increase in output impedance.
Note that an shorted load will not blow the output devices unless there is a AC signal present (i.e. playing music.) The DC offset is too small to generate significant current even with the BOM value for R14 = 1 ohm.
RJM Audio website|blog
Old 17th September 2011, 07:36 AM   #12
Richard Murdey
rjm's Avatar
So, this afternoon I put my 14s1 Sapphire on the bench and gave it a thorough going over with the voltmeter. Before I post some photos and lose your attention for good, let me post some numbers and comments.
- with the rev 14 layout, putting the output and driver transistors on the same heatsink, I solved the "reverse thermal runaway" issue that, in the rev 10 prototype, caused a significant reduction in output bias. I'm getting within 10% of the worksheet values, that 10% difference is most likely because the calculation assumes the devices are at the same temperature when in reality the drivers are a little bit warmer as the thermal coupling is not 100%.
- every other test point is spot on.
- in my build I have R10,R11 = 360 R and R6 = 13k. All other values as per the BOM.
- Talema 62062 transformers, but I'm running on 100 VAC line (Japan) so the effective secondary rating is 10.7 V rather than 12 V.
(I adjusted my version of the worksheet to reflect those changes before comparing the measured and calculated values)
Unrectified DC is +/-15.7 V. Regulated voltage rails are +/-10.8 V.
Measured driver current is 28 mA [calc=measured]. Measured output bias is 19 mA [calc=measured*1.1]. With my HD600 headphones, 23 dB gain and 64 mW of class A output power (calculated).
-The only surprising thing, to me, is how hot things got. Total heat for the stereo amp is 5 W, 0.5-1 W per heatsink. Overall the whole case gets comfortably warm when left on for a while. The heatsinks with two transistors against them are just cool enough to be able rest your finger against. Probably about 55 degrees C, or 20 C degrees above ambient (it's still hot here). My conclusion is that I would not want to increase the bias currents much above what they already are without a complete rethink of the thermal design of the amp.
Final word: Sapphire rev 14 works as designed, and is pretty well optimized at the current circuit values.
Old 17th September 2011, 07:43 AM   #13
Richard Murdey
rjm's Avatar
(after fitting the new rev 14 boards)
- R6 is 13k tantalum, I grabbed them at hifi DIY store in Osaka.
- R10,R11 is the 360 ohm resistors from my proto built and were spliced in there after I mistakenly fitted 330k ohm resistors in there by mistake.
- The heatsinks are the wrong size, but they'll do until I get the new ones.
- The bridges, for the record, are 400V 50A each.
[Nikon D40, Ai micro-Nikkor 55mm F3.5]
Old 18th September 2011, 01:29 AM   #14
Richard Murdey
rjm's Avatar
above should have been: R7 is 13k tantalum (gain set resistor, giving +8dB over the standard BOM config. to better match my 300 ohm headphones.)
Old 18th September 2011, 08:18 AM   #15
simonov is offline simonov  Bulgaria
simonov's Avatar
Btw, where do you source those nice enclosures from? I want one of these
Venci.
Old 18th September 2011, 12:13 PM   #16
Richard Murdey
rjm's Avatar
Here.
Old 18th September 2011, 05:56 PM   #17
Earfanatic is offline Earfanatic  Hungary
Venci.
Ebay is another source. I saw this there several times.
By the way RJM, the Sapphire looks good. Good job!
Old 30th September 2011, 08:41 AM   #18
Richard Murdey
rjm's Avatar
I was scouring the internet for headphone amplifier circuits similar to the Sapphire : a current buffer running open loop, with either a discrete or integrated voltage front end. Other than the 47 labs model 0147 I haven't found anything. Dozens of diamond buffer variants out there, all complications of the basic LH0002 caliber - I think I've seem most of them now. Several "diode biased push-pull transistor pair" output stages stapled into the op amp feedback loop. Nothing I could really point to and say "hey that's pretty much the same as the Sapphire."
I'm interested because I'd like to know how other people approached a similar design, what they did differently, and why, maybe learn some new tricks.
Anyone care to point me in the right direction?
Old 1st October 2011, 12:20 PM   #19
simonov's Avatar
BUF634 is a diamond buffer too. It uses CCS instead of emitter resistors for improved thermal stability.
Old 2nd October 2011, 06:08 AM   #20
Richard Murdey
rjm's Avatar
True, there's that. Still available too, I though it was discontinued for some reason. Unfortunately it is fixed at about 6 mA quiescent current, so it more-or-less has to be used inside the feedback loop.
I was searching instead for example circuits where the output buffer is run open loop.
RJM Audio Sapphire Desktop Headphone AmplifierHide this!Advertise here!
RJM Audio Sapphire Headphone Amplifier rev14a1 kit rjm Group Buys 14 2nd September 2016 11:23 PM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 7th September 2011 11:59 PM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 06:55 PM
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 04:23 PM
FS: DIY Cavalli Audio Embedded Hybrid Headphone Amplifier sachi Swap Meet 4 19th May 2010 09:43 PM
