Headphone Systems Everything to do with Headphones
RJM Audio Sapphire Desktop Headphone Amplifier
Old 27th December 2016, 07:16 AM   #1011
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
No, JFETs are out of the picture as the circuit needs the precise emitter-base pn diode reference voltage of the BJTs to correctly set and stabilize the bias currents throughout the rest of the circuit.
Working/prototype BOM attached. (Unity 1.0e)
RJM Audio website|blog
Old 27th December 2016, 10:58 PM   #1012
Richard Murdey
rjm's Avatar
Please see the blog post for the most recent BOM. There are a couple of edits from the version posted above.
The boards are on order. I should have them mid-January.
Old 28th December 2016, 04:26 AM   #1013
Richard Murdey
rjm's Avatar
or...
we could just go back to a simple drop-in replacement for the older boards, with the regulator built in.
I like this, since it means I can listen to the new version with minimal fuss.
Old 28th December 2016, 05:40 AM   #1014
Stan63605 is offline Stan63605  Canada
Originally Posted by rjm View Post
or...
... a simple drop-in replacement for the older boards, with the regulator built in.
I like the sound of that, too!
Old 28th December 2016, 09:59 AM   #1015
Richard Murdey
rjm's Avatar
Glad to hear that because I've gone ahead with this version! (4.0b)
Here's all the info. (For download: Gerbers, LTSpice, and BOM)
Old 29th December 2016, 12:04 AM   #1016
Richard Murdey
rjm's Avatar
b1 BOM fixed several part numbering errors, added some notes and alternates
Old 10th January 2017, 05:11 AM   #1017
Richard Murdey
rjm's Avatar
Sapphire 4.0b boards are back from fabrication. Also Unity (H) and the various voltage regulator boards.
2 oz copper, 2-layer, black mask, 80x100 mm.
Old 12th January 2017, 06:48 AM   #1018
Richard Murdey
rjm's Avatar
BOM revision 4.0b2
I made some adjustments to the resistance values of the output stage to lower the output impedance a bit. It's about 3 ohms now, vs 7 ohms for the b1 configuration.
R11,12 465 ohms -> 221 ohms
R17-20 10 ohms -> 4.7 ohms
R1 is made 1k, though this is a rather arbitrary value.
R2, R3 and C2 - the gain setting components - have been adjusted slightly. Please refer to the table in the BOM Gain Calculator page. The defaults are now 2k2, 22k, and 10pF respectively. Since this is a current feedback circuit, these components are somewhat of a pain to finesse, but the simulation can be helpful to understand the relationships. Reducing R2 cranks up the open loop gain. This is required to obtain useful bandwidth at high closed loop gain (i.e. circuit gain), but is relatively unstable so a higher value of C2 is needed for compensation. For low closed loop gain R2 can be relaxed since there is plenty of available bandwidth. Less compensation is required here. The closed loop gain is approximately R3/R2 though it is slightly more complex than that in reality especially for high values of R3.
Old 12th January 2017, 12:40 PM   #1019
Richard Murdey
rjm's Avatar
Did the smoke / operating point test.
One board is perfect, the other had -2 V offset that fell out of the range of the trimmer R6. I found the problem was the Zener diodes, which were not well matched so the positive and negative rails were 0.25 V different. If R6 is 1k that only gives 0.1 V of adjustment, not enough to compensate.
This can be solved by matching the Zeners to closer tolerance, but the basic failure here is R6 was too small a value. Increasing R6 to 5k allows about 0.5 V adjustment, which should cover just about any eventuality. You can use 10k if you want.
Since I don't have any 5k trimmers on hand, I'll match some Zeners tomorrow and replace the oddball.
In point of fact I matched the transistors well enough that the trimmer is hardly needed, removing it would actually improve the situation in this instance since the offset is introduced into the input by the power supply through the trimmer itself.
Old 13th January 2017, 05:08 AM   #1020
Richard Murdey
rjm's Avatar
Bench notes, DC operation:
My roll of "12V" Zeners seem to come in two flavors of breakdown voltage. Of seven tested, three were 11.5~11.6 V, while four were 11.2~11.3 V. Odd but that's what I have to work with.
Using one of each type for D1,2 means |(V+) - (V-)|= 300 mV and the center of the trim pot moves 150 mV away from zero. For a 1k pot as R6, the adjustment range is 100<->200 mV i.e. insufficient as zero is out of the trim range. For a 5k pot the range is -100<->400 mV, which is ok.
To fix my board though all I had to do was swap out the 11.6 V D2 Zener for an 11.3 V one to match D1. Now 0 mV it is in range of the 1k trim. In my case it was easier to match Zeners than order a new trim pot, but as I mentioned last post the BOM is updated to increase R6 to 5k.
The output offset of both boards (configured for 26 dB gain with R2 = 475R and R3 = 22k1) after trimming is +/-50 mV cold and +/-10 mV warmed up. The trim setting is so close to zero though it is unclear if the offset adjustment is even needed. If 50-100 mV output offset voltage is acceptable it can probably be left out in favor of a simple 47k resistor to ground, but ultimately its probably safer to keep the trim option.
The bias current is about 40 mA, and the heatsinks barely get warm to the touch, so there is plenty of thermal headroom if higher bias currents are desired. This is accomplished by increasing R11,12 from 221 ohms to 332 ohms or even 475 ohms.
RJM Audio Sapphire Desktop Headphone AmplifierHide this!Advertise here!
RJM Audio Sapphire Headphone Amplifier rev14a1 kit rjm Group Buys 14 2nd September 2016 11:23 PM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 7th September 2011 11:59 PM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 06:55 PM
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 04:23 PM
FS: DIY Cavalli Audio Embedded Hybrid Headphone Amplifier sachi Swap Meet 4 19th May 2010 09:43 PM
