RJM Audio Sapphire Desktop Headphone Amplifier - Page 10 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 10th July 2012, 01:01 AM   #91
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
The price difference isn't as great as I thought. 75 cents each for C0G vs. 25 cents for X7R (Mouser). Don't take that as an endorsement, mind you, just that people who are in the habit of paying $20+ for coupling caps might want to consider trying this "upgrade".
For bypass applications, I remain skeptical.
RJM Audio (phonoclone.com / G+)
Old 9th May 2013, 08:46 AM   #92
Richard Murdey
rjm's Avatar
Photo of a recent Sapphire build. The chassis ground is a heavy screw mounted between the L and R rectifier banks and the transformers. The circuit common is connected to the chassis ground from the COM pads on the board.
This seems to be the best way to do it.
Note that there are a pair of COM pads on the boards, but the are electrically bridged. You can use one or the other or both, it doesn't matter, I just included two to make it convenient to connect two bridge rectifiers per channel.
If you have one pad spare, you can use it to ground the boards to the chassis.
The reason there in no explicit "GND" pad like the Phonoclone/VSPS boards have is I imagined most people might be using headphone sockets which have the COM ring (gnd) in electrical contact with the socket housing, which, for a metal front panel, grounds the circuit by default. As it turns out most people use insulated sockets and make the chassis-to-circuit-common connection elsewhere - in which case, I suggest the COM pad.
Old 10th May 2013, 01:36 PM   #93
Richard Murdey
rjm's Avatar
THD simulation for the BOM version of the J-Mo Mk. II, driving a 16 ohm load.
40 mW output at 1% THD (mostly second harmonic)
Old 13th May 2013, 12:41 PM   #94
GLooP is offline GLooP  Bulgaria
Once again great work, RJM. Your stuff is very inspiring. Keep it up.
Best,
GLooP
Old 14th May 2013, 06:22 AM   #95
Richard Murdey
rjm's Avatar
I mistakenly posted this to the wrong thread. It belongs in the J-Mo Mk. II thread instead, as a followup to this post.
Old 26th November 2013, 10:07 AM   #96
Richard Murdey
rjm's Avatar
Default Revision 2.0
This looks to be about the final revision before sending off for fabrication.
The new boards are drop in replacements for rev. 1.4s, and the circuit can default back to the original if desired.
The main changes are the addition of a Zobel network on board, ceramic bypass capacitors on board, and an additional pair of resistors to increase the bias current through the output transistors. The parts numbering has been completely changed, however, and I will be updating the documentation to reflect that.
There will be 9 sets of boards available, and will do a limited edition kit if the interest is there.
Old 27th November 2013, 10:21 PM   #97
Whats the story on the zobel on the output Richard? Have you found it particularly beneficial with any cans in particular or either end of the impedance spectrum?
Fran
Old 28th November 2013, 02:51 AM   #98
Richard Murdey
rjm's Avatar
No, I can't say it makes any difference, but maybe it does. It's a comfort blanket, so you can rest secure in the knowledge you have that particular base covered.
Old 29th November 2013, 11:19 PM   #99
Richard Murdey
rjm's Avatar
Updated links for the aluminum chassis I used to case up this amp.
Headphone Amplifier Aluminium Chassis 01 [Case 01] - $75.00 : DAC,Audio Amplifier,Hifi Amplifier,Tube Amplifier,Hlly Audio, Hlly Electronics
Headphone Amplifier Aluminium Chassis 02 [Case 02] - $75.00 : DAC,Audio Amplifier,Hifi Amplifier,Tube Amplifier,Hlly Audio, Hlly Electronics
AT $75 shipped the price is very reasonable, I would go so far as to say dirt cheap considering what you get.
Old 30th November 2013, 07:30 AM   #100
You night want to take a peak at this
Class B amplifier has automatic bias | EDN
G
RJM Audio Sapphire Headphone Amplifier rev14a1 kit rjm Group Buys 14 3rd September 2016 12:23 AM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 8th September 2011 12:59 AM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 07:55 PM
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 05:23 PM
FS: DIY Cavalli Audio Embedded Hybrid Headphone Amplifier sachi Swap Meet 4 19th May 2010 10:43 PM
Copyright 1999-2017 diyAudio
