Yet another simple class A headphone amp - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 23rd August 2011, 09:32 PM   #1
1001 is offline 1001  Italy
Question Yet another simple class A headphone amp
hello everybody,
I'm going to test this simple amplifier for my 32 ohm sennheiser hd 448, the voltage gain is 2.5, the rms output power is a little bit more then 100 mW (32 ohm load and my ipod nano), all discete bipolar never switch and the output stage of AD797 too. what do you think about this circuit? maybe there are some errors...
Old 24th August 2011, 05:22 AM   #2
It should work quite well, I would probably make C7/C8 larger. I'd probably make R2/R11 4.7 ohms as well
Old 24th August 2011, 08:53 AM   #3
well, good tips, but what do you think about sound quality?
this net would be free of crossover distortion (AD797 too) due to class A biasing, it would has very low output offset (absolute and thermal drift) and very low noise.
I'm going to do this circuit and test for noise, stability, dc offset, stability of biasing current, offset thermal drift, quality of sound and reliability.
Old 24th August 2011, 07:08 PM   #4
I will read Your comments so please keep posting. I like the low part number high quality designs. I'm also interested in how the final amplifier will look like (PCB mania or something...).
Old 24th August 2011, 07:41 PM   #5
jcx is offline jcx  United States
if you learned how to use this free schematic drawing tool you could gain some more insight about how the circuit works
Linear Technology - Design Simulation and Device Models
I've simmed simialr topologies Cmoy headphone amp?
Old 24th August 2011, 09:34 PM   #6
Originally Posted by jcx View Post
if you learned how to use this free schematic drawing tool you could gain some more insight about how the circuit works...
I did a preliminary sim of my circuit before a future testing to check the feasibility, I need to know if it is enough stable, how the thermal drift can change the biasing current of the output stage and possibly fix it.
if the circuit pass this test it 'would' be better for instance of any cmoy or O2 amp, with lower output impedance, lower distortion, lower noise but it needs more current because of its full class A design.
Old 25th August 2011, 02:24 PM   #7
while I am waiting to receive toshiba bipolar from an ebayer seller to test my circuit, I am simulating another all class A topology, just a little bit stranger: this is the open loop gain of the whole amp, with 207 dB of gain @ 20Hz and 102 dB @ 20 Khz
hypothetically, if it is real what do I expect from this amp? does it sound better than conventional amp?
Old 26th August 2011, 05:00 AM   #8
everything has its limits - feedback factor grossly exceeding your S/N is fairly useless, "costs" you in needing higher loop gain roll off rate, actually reducing available feedback factor at higher frequencies
http://trs-new.jpl.nasa.gov/dspace/b.../1/98-0905.pdf doesn't explain the noise limit but does show the basic "conservation law" of feedback
for headphones heavily biased output buffers can have few 0.1% "open loop" distortion, adding 80-120 dB loop gain likely gives as much performance as can be distinguished from system noise at audio frequencies - ears do not do 10s or 100s of seconds of averaging to reach down into the noise floor like we can with fft
Old 26th August 2011, 11:49 AM   #9
...actually reducing available feedback factor at higher frequencies...
my design has 102 dB @ 20 Khz open loop gain, I think no one opamp have the same gain. of course the stabilization network decrease available feedback factor but at higher frequencies, over 70-80 khz (in my design).
I agree, but since I had made and tested this network but without output stage many years ago, I think it could interesting to test the circuit by AP equipment and for sonic performance. don't you think it's a good idea?
Old 26th August 2011, 11:57 AM   #10
Default Headamp
Please see here:
http://www.ac-vogel.de/TransBuffer_A...fer_APN_1.html
This amp is tested by Audio Precision 2 and works with several Loads.
Don't forget heatsink :-)
Designing audio electronics isn't a job, it's a mission
Simple Class A Headphone Amp Using THAT1646 mediatechnology Headphone Systems 26 21st February 2017 11:26 AM
Simple headphone amp with mixing inputs? tuck1s Chip Amps 6 27th January 2011 05:36 AM
TSHA.. A very simple Headphone Amp idea.. Dxvideo Headphone Systems 15 1st February 2009 07:04 PM
Simple Headphone Amp Nico Ras Headphone Systems 69 8th August 2008 12:19 AM
Discrete simple headphone amp kubeek Headphone Systems 15 7th September 2007 04:13 PM
Copyright Đ1999-2017 diyAudio
