| Headphone Systems Everything to do with Headphones |
#931 |
Actually I have no idea of who that might be... ;-)
Now, I hope this OT didn't bother you to much RS. |
#932 |
Is that module generally available in single piece quantities to DIYers? What USB chip is it based on? Does it provide MCLK for the DAC? And does it require a proprietary driver or is it fully UAC1 compliant?
http://nwavguy.com - Personal non-commercial audio blog |
#933 |
Is it the M2Tech hiface? I think that has its own drivers instead of UAC and I think they no longer supply the modules. Is that right?
#934 |
M2Tech Hiface - "Internal very low jitter oscillators and proprietary drivers allow for playing 192kHz/24bits audio files that feature the best signal quality."
M2Tech Hiface EVO - "Asynchronous operation up to 192kHz is used in conjunction with proprietary drivers which allow for Kernel Streaming, Direct Sound and WASAPI operation (the latter under Windows vista and 7)."
These are my principles, and if you don't like them... well, I have others. |
#935 |
is choosing a less facetious title...
Turbon is correct, its an OEM module based on tyhe same chipset and basic design as the Hiface. A while back a GB on here for it was stopped in its tracks because the datasheet was made public and they were made aware of it, so they never supplied it to the general public. i went ahead bought them legit as an industry professional, but i think you would struggle to get them to come to the party with licensing and the lack of a UAC2 driver is probably another deal breaker for you. it does expose all the power supplies, i2c and control pins as well as i2s.
so because i have them already the 98 dollar ES9023 dac deal is a screaming winner for this dac/amp i'm making for my friend. |
#936 |
ES9023? Interesting. I'd love an ES9012 DAC running UAC2 (& UAC1) feeding an ODA or "The Wire" tuned specifically for my AKG's power range.
#937 | |
no need for tuning for AKG, unity gain is perfect for ~60ohms but that assumes you are running regular AKG. i cant remember if you had 240's or k1000 or something nuts =) kids run away before the DIY bug gets you!! Last edited by qusp; 29th November 2011 at 01:24 AM. |
#938 |
Wow... your setup is pretty much my persuit. Anyway, I'm rolling with the K 171 Mk II headphones, so unity is probably fine because a gain of ~1.6 would be my max from 2V feed and I would want to use more than the first 1/3 of the volume pot.
It's amazing how much better they sound amped... and I'm a quiet listener. Last edited by ethanolson; 29th November 2011 at 03:38 AM. Reason: Omitted first line by accident |
#939 |
@qusp,
Why does everyone have I/V stages for their ESS DACs? Don't they have a voltage output option? TPA does it. AckoDAC does it. And others, as well. Does current mode sound better even with the I/V circuit? |
#940 |
@ethanolson, the short answer to that question is most DIYers design "blind" without proper test equipment and using only heavily biased sighted listening as their guide. They very often think they hear things that don't really exist as has been demonstrated countless times in blind listening tests. if you throw a bed sheet over the equipment, without changing anything else, the benefits they think they hear magically disappear. So it's easy to see how they think adding an op amp stage to a DAC chip improves the sound when in reality it might make the performance a bit worse.
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
