The Objective2 (O2) Headphone Amp DIY Project - Page 61 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 1st November 2011, 02:12 AM   #601
agdr is offline agdr  United States
agdr's Avatar
Originally Posted by tschuss View Post
It would be nice to hear from more people on what they're using, but I think we're all just getting ready to build, so there's not a lot of info out there yet.
Suggestion: for 25 cents more you can get the 16VAC 1000mA unit at mouser:
WAU16-1000 Triad Magnetics Plug-In AC Adapters
vs
WAU16-400 Triad Magnetics Plug-In AC Adapters
RocketScientist has them both on the BOM as alternatives. Take a look at the SPICE sims I posted in this section a couple of days ago for the O2 at max load. The (rms transformer secondary current rating) current de-rating factor for half wave rectifiers with capacitor input filters is 0.28 as per
http://www.hammondmfg.com/pdf/5c007.pdf
so that would give you about 112mA total, including amp quiescent, without saturating the trasformer core. That would be around 50mA per channel which is enough for a lot of - probably most - headphones. But with the 1000mA unit you can get the whole banana, 280mA max (130mA or so per channel plus quiescent), the amp is capable of.
I've seen some info about transformers generating noise bursts when the core comes out of saturation, but haven't been able to confirm it yet. May be total bunk - RocketScientist would have seen it in his noise measurements. But at the least core saturation on the current peaks would cause some temperature rise.
At any rate, if you are ordering an xformer from mouser anyway, may be worth paying the additional quarter. The 1000mA unit is heavier any may add $1 to shipping too, don't know.
Old 1st November 2011, 02:37 AM   #602
tschuss is offline tschuss  United States
Thanks, agdr.
I might end up doing that just to have the versatility of an extra "wart" around.
This will be a portable amp for me, so it will be unplugged roughly 90% or more of the time. For my usage, the adapter is simply to recharge the batteries. However, I wasn't sure if that would happen if the output was less than 13.5V, which is why I questioned the use of the original 12-200.
As I've stated before though, my understanding of these things is very, very limited. It could be that the 12-200 is more than enough as a simple charger, even if it falls below the 13.5V minimum.
I *think* the diodes act like switches, and only allow current flow if the voltage is greater than 13.5. If that understanding is correct, then I'll probably get the 16-1000 or 16-400. If not, then the 12-200 is probably the right choice, as I won't need more for a simple charging circuit. Please feel free to correct me if I'm wrong.
Forgive my lack of knowledge about such things. If we were discussing something within my realm of study, I could actually ADD something to these boards. As it is, I fear I am purely a "taker" at this point.
Thanks again for everyone's help. You make DIY more fun.
Old 1st November 2011, 03:32 PM   #603
agdr's Avatar
That is a good point about just being used for charging duty, tschuss. The maximum charging draw for just the batteries, without the amp powering anything, would be around [(11.8V - 8.0V) / 220R ] * 2 = 35mA, then add another 30mA or so for quiescent current from all the chips, for around 65mA or so. That current draw drops rapidly as the batteries charge, too.
The 200ma(rms) secondary would work out to be around (200mA)(0.28) = 56ma(dc) after the half wave rectifiers, so that 12v/200mA unit might be thin even for just battery charging. The 16VAC 400mA wall wart might do the best job in your case, for charging duty.
One thing I should add to the above post, that issue of "music power". These are all DC current calculations, which would directly apply to battery charging. But as for the amp playing music the occasional music peak can come out of the filter caps, giving you some additional current capability there. But I always pick the conservative side (how many peaks will there be in any given music, and how long will they last?) and go with the DC values, especially since the transformer price is nearly the same for 400mA as 1000mA.
Old 1st November 2011, 06:09 PM   #604
sofaspud's Avatar
That roughly matches my estimates, but the quiescent current is <<30mA when only charging the batteries. IMO the 12-200 should work fine for that.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 1st November 2011, 06:29 PM   #605
This is assuming it can output 13.5V while loaded, correct?
My concern is not about the *current* output capability of the 12-200, it's about the *voltage* output. If it can't supply a minimum of 13.5VAC under load, then the current is a moot point, right? The diodes simply won't "open" until they see that voltage.
Again, please forgive me if this understanding is not correct. I'm just trying to gain some knowledge.
Thanks!
Old 1st November 2011, 06:55 PM   #606
sofaspud's Avatar
Yes, I'm making that assumption.
You're correct about the diodes as switches, but the transformer voltage has to do with the ripple and peak charging voltage seen by the reservoir capacitors, combined with the action of the regulators. The regs need a bit of "overhead" (the dropout voltage) to maintain 12V regulation.
Old 1st November 2011, 08:20 PM   #607
sofaspud's Avatar
I'm kicking around the idea of having an external DC option. It would deliver +/-15V to the regulator inputs using a DC-DC converter, and could be powered via battery pack, USB, lighter plug, etc. RocketScientist has some DC-DC coverage in his blog, and I'm thinking the regulators will provide maybe -30dB rejection, making it a little quieter than being directly connected. Charging convenience is obvious. Any advice/opinion/scolding that may be helpful to me?
Old 1st November 2011, 09:50 PM   #608
Advice: Haha. Yeah, right. I receive the advice around here. I'm in no position to give it.
Opinion: That sounds great! I would really be interested in such an option, especially the ability to use a lighter plug.
Scolding: See "Advice", above.
Old 2nd November 2011, 02:36 AM   #609
agdr's Avatar
I have to admit to a brain hiccup on my charger current calculations, above. Thinking about it some more this afternoon I realized that the typical half-wave rectifier math, as in that Hammond app note, is for the typical configuration of just one diode. With one diode the other half of the AC waveform gets thrown away, which is why the secondary current de-rating factor is less than 50%. Not very efficient.
But RocketScientist's circuit is essentially a double half-wave rectifier, or more accurately a voltage doubler circuit, which IS making use of the other half of the incoming AC waveform. Which means the load on the two channels has to be treated separately and matched up with the capability of each rail's half wave rectifier. In the case of the 12VAC 200mA(rms) transformer, each rail gets 200mA * 0.28 = 56mA max to avoid core saturation, which is better. However that gets mitigated a bit by my underestimating the total chip quiescent current draw. I whipped out the data sheets and the total for all the chips is around 42mA, with some of it rail-specific (the LM regulators) and some of it rail to rail (the op amps).
The net result is that to the 17mA or so of max charging current per battery, add around 30mA of quiescent current and you are at around 47mA per rail. So that 56mA available per rail from the 12vac 200mA(rms) charger works just fine, plus leaves some for the amp output itself (and even more as the batteries charge and the charging current goes down).
That result makes more sense as a double-check, given that RocketScientist did the original measurements with that particular adaptor and it worked just fine for the headphone loads he tried. For using the amp with music though, along with charging, that 16vac 400mA unit would be a good idea. Figuring in the two half wave rectifiers now, and adding in battery charging current which I forgot initially, that one would leave 70mA - 90mA free per channel (rail) for the amps themselves, much more than that 50mA I came up with above. That much current will probably cover most headphones just fine. And for the full 130mA or so per channel the amp is capable of, get that 16VAC 1000mA transformer.
Also FWIW I finally found a good writeup on why you want to avoid transformer core saturation in the first place
Core Saturation - Transformers
That "noise" I had read references to in saturation is harmonics of the line fundamental frequency (60Hz or 50Hz) that get generated by the core saturation, plus waveshape distortion occurs. The harmonics heat up the transformer and can conceivably find their way onto the power supply rails depending upon regulator and filter rejection.
Old 2nd November 2011, 03:21 AM   #610
sofaspud's Avatar
re: underestimating the total chip quiescent current draw
I used a battery cutoff of 6.7V, which is 7V at the battery, due to D2; (~1V/cell was the design target). But when charging only, there is no current past the power switch. FWIW, I think RS spec'd the charge current at 2 times 24mAmax with 220 ohms and the Tenergy NiMH.
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 06:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 03:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 04:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 03:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 16th April 2004 12:22 AM
Copyright 1999-2017 diyAudio
