| Headphone Systems Everything to do with Headphones |
#581 | |
#582 |
On the topic of batteries, it seems "9V" NiMH batteries from "reputable" North American suppliers mostly have capacities on the order of 200mAH, with a few topping 300mAH. But there are eBay sellers from Hong Kong selling batteries rated at 400 and even 450 mAH 4 x 9V 9 Volt 400mAH PP3 NiMH Rechargeable Battery uc | eBay and 2 9V 9 Volt 450mAh Ni-MH 6F22 PP3 Rechargeable Battery Cell Block | eBay .
Does anyone have experience with these? Are these for real? For about $5/battery they seem to be offering almost twice the capacity of name-brand batteries. |
#583 |
I
#585 |
Hi guys-
A question for those of you in the US/Canada who have built and are actively testing/using the amp: Are you all using the recommended Triad WAU12-200 AC adapter? The reason why I ask is that it seems to me that the listed specs on that particular model are really, really close to the minimum needed to operate the amp. It won't be used with any abnormally high-impedance cans, and will also be used via battery power probably 90% of the time, but I just wanted to make sure that the adapter does indeed work exactly how it should (especially in terms of charging the batteries). I'm giving a couple of these as gifts this year to non-DIYers, and obviously don't want the recipients to worry about the units working correctly. I trust that NwAvGuy did his homework correctly, but I guess it just makes me a little nervous with only one data point. Is everyone else having good luck with that model too? Thanks! |
#586 | |
#587 |
Right, I hit nightly maintenance and somehow only posted 1 letter. What I meant to reply with was:
I'd call this 'Creative twisting of the truth', if anything. The difference in capacities often relates to the number of cells in the battery, for 9V you can have lower nominal voltage and more capacity, or higher voltage with slightly less capacity. I recommend something like Maha Powermax - 300mAh, with low discharge. Reasonable capacity and you don't need to worry about them losing power while you're not using them. |
#588 |
Whdemon
please, always post a comment, and not only a quote ![]() moderation |
#589 | |
Thanks Mr Demon, but I have already read that section. I'm looking for others' experience. As a colleague of mine used to say: "You can draw a lot of lines through a single data point"
#590 |
I just received my PCB, so I can't post from a position of experience with the Triad WAU12-200. Personally, if I were buying new from Mouser, I'd probably go with the WAU16-400. I have a couple 5-gallon buckets full of wall warts, and plan to try (in order) three rated at 12VAC 250mA, 12VAC 300mA, and 16VAC 1000mA.
As to working as it should to recharge the batteries, it's only job is to supply power to the cathodes of the Schottky diodes. R1 & R2 do the rest. You could probably use a little bit higher resistor values to limit the current further, at the cost of extending the time needed for full charge. It might not be a bad idea to match the resistor values to the battery used.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
