Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 13th October 2011, 03:32 PM   #531
Michel01 is offline Michel01
Originally Posted by MrSlim View Post
No one is selling complete kits..
You'll need to check the O2 board group buy and see if there are any spares left, order your own parts from the BOM, and if you want, get in on the Front Panel Group buy..
Ok Thanks
Old 20th October 2011, 06:24 PM   #532
Turbon is offline Turbon  Sweden
Turbon's Avatar
Default Portable dac?
Which DIY one would you recommend fitting in an equal sized box as the O2 or if it would fit in a slightly bigger box containing the both of them. Of course there has to be switches so one is able to use just one of them or both at your command :-)
Old 20th October 2011, 06:36 PM   #533
MrSlim is offline MrSlim  Canada
In case anyone is planning on doing a mini Desktop and either using the standard panels included with the B3 boxes or getting panels from the Group Buy that is ongoing, the 1/4" jack that RocketScientist(aka NwAvGuy) included in the BOM will not work due to its requirement for a 1.2 - 1.5 mm panel thickness..
An alternative I found with approximately the same physical dimensions and less specific requirements for the panel mounting is the Neutrik NRJ3HF-1 and NRJ-NUT-B combo (Mouser#s 568-NRJ3HF-1 and 550-1005)
Old 20th October 2011, 06:43 PM   #534
The Grub Dac from Beezar.com might fit the bill for you, although you'd have to figure out how to mount the board and connectors.. You could probably put it in the B3-080 desktop case along with the O2....
Old 20th October 2011, 06:43 PM   #535
Willakan is offline Willakan  United Kingdom
Bugger. Looks like I will be doing some first-class botching, seeing that shipping from Mouser is eyewateringly expensive in the UK and most places have minimum orders.
Old 20th October 2011, 07:01 PM   #536
Turbon's Avatar
Thanks MrSlim, I'll check it out but tubes? what are they for? buffering?. I need no amplification since I'm going for the O2 but still, I'll look into them.
Hmmm, sorry - the grub dac looks intressting... But, the input is limited to 16/48 on usb. I am more in search for 24/96 as a minimum without amplifier.
Brgds
Old 20th October 2011, 07:10 PM   #537
Turbon, no, they have tube amps.. but the Grub and skeleton dac are tubeless..
Old 20th October 2011, 07:16 PM   #538
yiihaw is offline yiihaw  Finland
I'm new here, and just wanted to drop a thank-you to NwAvGuy/RocketScientist for the great design and everyone organising the GB's to help materialize this amp. Very much appreciated!
I currently enjoy my music with a FiiO E7/E9 combo and a pair of HD650's. Can't wait to put together an O2.
Old 21st October 2011, 10:04 AM   #539
sgrossklass is offline sgrossklass  Germany
The O2 probably won't sound any different than the E9 for you, since even the latter's 10 ohm output impedance is plenty low for HD650s, and about 160 mW of power should be ample, too.
Anyway, the O2 should be a fun project, and you'll be happy you got one the moment you acquire some multi-driver IEMs or other similarly fussy headgear.
Old 21st October 2011, 10:52 AM   #540
Yeah, I realise that, and I'm not really expecting any change in SQ (and I'm very happy with the FiiO). Anyhow, the thoughtful design of the O2 is what really sold it for me, and the O2 will primarily serve as a semi-portable, easy-to-pull-out-and-put-away amp for home listening, as the E7/E9 is my office setup and a bit too much of a hassle to move around. I also have other much more sensitive headphones, which might benefit from the O2 as well.
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
