Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 30th September 2013, 07:16 PM   #3431
availlyrics is offline availlyrics  India
availlyrics's Avatar
Originally Posted by Vigo View Post
...The gain button, what does it do?
The gain switch gives 2 options-
High-gain for high impedance/low sensitivity cans/ weak input sources like mp3 player/ipod e.t.c.
Low gain(recommended) for low impedance/high sensitivity cans/ strong input sources like ODAC/CD player line out
further reading NwAvGuy: O2 Details
Thanks,
availlyrics
Old 1st October 2013, 02:00 AM   #3432
agdr is offline agdr  United States
agdr's Avatar
Originally Posted by sonichedgehog36 View Post
I am looking into alternatives to Q1 and Q2 since I may or may not be able to get the samples from Fairchild.
I wouldn't have any suggestions there, but those mosfets are around $0.80 at Mouser. Hard to beat that.
Old 1st October 2013, 03:35 AM   #3433
sonichedgehog36 is offline sonichedgehog36  United States
OK. Thank you! The ever so slightly pricey part about the shipping, not the product itself, is what bothers me.
Old 1st October 2013, 11:15 AM   #3434
Vigo is offline Vigo  Sweden
Vigo's Avatar
Thank you availlyrics, good explanation
To play with OP-amps in audio is like playing card with devil, you can never win.
Old 1st October 2013, 12:51 PM   #3435
mcandmar is offline mcandmar
Try living in europe, anything you buy costs at least 20 to ship, or if you spend over 60 you get free shipping... so before you know it you have bought 40 worth of crap you didnt need just to get that one part you did. Damn you mouser
Old 3rd October 2013, 03:44 AM   #3436
I am a first class cheapskate--or would that be third class, saddled camel through the Arabian desert, canoe braving the ocean waters, all in the name of that last cent, no better than Scoorge McDuck, cheapskate?
I am going to order from Digikey using the free shipping via check or money order trick. Since it's been a while, it took me some time to remember that Digikey had that special clause in place (see #6 http://dkc1.digikey.com/us/en/mkt/Terms.html ). Just pay about half a buck for postage, enclose your check or money order and--presto!--free shipping.
UPDATE: After further explanation to the Fairchild representative, I now have the parts on delivery, five each of the stock MOSFETs. No Digikey for now. Luckily, I did not strike the ink to the check yet!
Old 8th October 2013, 06:18 AM   #3437
I got the parts and put them in with plenty of TLC, as well as proper grounding and heat protection. Something is clearly still wrong--I am getting 17.5 volts DC across the outer battery terminals. Could the other TO-220 chips be the culprit?
Old 8th October 2013, 01:25 PM   #3438
Maybe thats right, 9v x2 = 18v. Have you tested these points,
Old 8th October 2013, 01:29 PM   #3439
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Take voltage measurements along the power supply path - AC input first, then ground referenced DC across the filter caps, regulator inputs, each side of D1 & D5. This can be done with the unit off and verifies the power supply operation.
If that checks out OK, the unit can be switched on and the DC distribution to the rest of the circuit can be checked.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 8th October 2013, 09:21 PM   #3440
Thank you everyone so far! Using this as a blueprint, and measuring as specified, ground (BT1-) to each point, but without U2 installed and the device "off":
BT1+: 17.32 V
BT2-: -0.01V
D3 (left/right): 18.06 V/ 0 V
D4 (bottom): -18.13 V
U4 (P4/P8): .67/.16
U2 (all pins): 0.01-0.02 V
D5 (top/bottom): Starts around 3.5 V, lowering/
D1 (top/bottom): 17.34 V/17.34 V
For reference, I am using all the recommended parts as listed in the BOM. Previous to voltage testing, all resistor values had been tested and verified.
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
