The Objective2 (O2) Headphone Amp DIY Project - Page 341 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 28th August 2013, 05:22 PM   #3401
Originally Posted by Zigis View Post
Probably too high gain.
Thank you for the suggestion Zigis, but, unlikely, switching the gain from 6.5 to 2.5 the distorion is still there (on the Cmoy I only have the default gain 9).
Northernsky
Old 28th August 2013, 06:29 PM   #3402
agdr is offline agdr  United States
agdr's Avatar
Originally Posted by ericj View Post
Is anyone currently selling nonmetallic faceplates?
Walter at Head N HiFi lists bamboo, acrylic and even leather in his pull-down list:
O2 Front Panel
Old 28th August 2013, 06:32 PM   #3403
agdr's Avatar
Originally Posted by northernsky View Post
I was surprised because I can clearly recognize an audible distortion by the O2 amp, especially audible on music with high power on bass.
What DC offset voltage do you measure on the output of each channel with nothing plugged into the input jack? Should be around 3mV or so.
If the offset voltage looks OK one thing to try would be new output NJM4556A chips, however they are not likely to both be bad. Is the amount of distortion about equal on both channels? Also take a DC voltage reading from the metal shell of the gain switch (ground) to pin 4 of either NJM4556, then again from ground to pin 8 and see what you get (the power supply rails).
Old 28th August 2013, 08:49 PM   #3404
Originally Posted by agdr View Post
What DC offset voltage do you measure on the output of each channel with nothing plugged into the input jack? Should be around 3mV or so...
Thank you agdr: you gave me my job for the weekend...
Northernsky
Old 28th August 2013, 10:18 PM   #3405
JZatopa is offline JZatopa  United States
Interested in a 3d printed one?
Old 28th August 2013, 10:31 PM   #3406
agdr's Avatar
Hey that is pretty slick! Just curious - can you make 2mm thick, same as the aluminum panel?
Old 29th August 2013, 08:45 PM   #3407
Here is a design someone has already created.
I am waiting for some parts for my printer and then I can print one for you. Let me do a test print and see what I get when I can.
Old 29th August 2013, 09:35 PM   #3408
agdr's Avatar
Wow, you've been able to print the whole case! That is fantastic. I haven't messed with 3D printers at all. I'm sending a PM. One of the reasons I gave up on this project
An "O3" - 35% smaller SMD RS O2 headphone amp version
was the case from Hammond was about 3/4" too short to use PCB mounted battery snaps instead of snaps on leads. Looks like your printer could kick out custom case sizes!
Old 29th August 2013, 10:52 PM   #3409
Just thought I'd mention that Shapeways - Make, buy, and sell products with 3D Printing is a great place to have your 3d designs printed. Just take a look at their material selection list:
3D Printing Materials on Shapeways
mmm, stainless!
Old 30th August 2013, 09:13 AM   #3410
availlyrics's Avatar
Northernsky
Assuming you are using DIP8 OPA2134 or so you can chk.-
each JRC4556 from O2 in your CMOY at low gain (2X and NOT 9X).
or/and
use the opamp in CMOY in the gain stage of O2.
Swap opamps one by one, listening to any audible distortion. Beware of offset voltages at o/p(not above 20mV) & use only elcheapos h/p for initial testing.
Thanks,
availlyrics
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 06:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 03:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 04:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 03:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 16th April 2004 12:22 AM
Copyright 1999-2017 diyAudio
