Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 2nd July 2013, 11:45 PM   #3341
burritoboy9984 is offline burritoboy9984  United States
Ok, I believe I am in need of some help. I went to take some voltage measurements of my O2 this am (was working perfectly). And when I touched pin 8 on U2 to measure the voltage, I got a spark, followed by the LED turning off. I looked down and noticed that my DMM had the leads in the incorrect positions (not sure if that was what caused the spark or not). I took out U1, U3 and U4, then got the following measurements. Thinking I fried the IC, I went out and got an LM393 (shows as the same chip as the LM2903 in the datasheet), hooked it up, and got the same exact measurements.
A couple of odd things to note the measurements from the sockets on U3 sometimes show 11.8 and -11.8 as it should (random, can't figure out what makes it correct). R5 when the power switch is off measures 235k and when the power switch is on measures 88k.
Any suggestions?
Thanks in advance!
Erik
Old 3rd July 2013, 01:54 AM   #3342
agdr is offline agdr  United States
agdr's Avatar
Those other lead positions on most DMMs are for current measurements. They result in the meter essentially being a dead short between the two leads. You most likely shorted out your power supply. The LED is directly across the power supply rails, which also sort of points to no juice any more. It only goes out if one or both power supplies are missing going into the mosfets.
With the AC adaptor plugged in and the batteries out, take a DC voltage reading from ground (metal shell of the gain switch) to the non-banded side of D1 (that is your +12V supply) and to the banded side of D5 (your -12Vdc supply) and see what you get.
If you had one meter lead on ground and touched pin 8 with the other, I'll take guess that you killed D1. If you were measuring pin 4 to pin 8 across the rails then D1 and D5 may both be open. Pin 8 is the positive power supply. U5, the positive voltage regulator, has some short circuit protection which leaves D1 as the weak link between the regulator and the short caused by the meter leads. It is also possible that you blew (fused) the positive PC rail circuit board trace in one or more spots. Take a good look at the traces on both sides of the board with a magnifying glass. Also, I'm assuming you were running on AC power when you touched the meter lead. If you were running on batteries instead then I'll guess that D2 is what's toasted.
Old 3rd July 2013, 02:08 AM   #3343
If you had one meter lead on ground and touched pin 8 with the other, I'll take guess that you killed D1. If you were measuring pin 4 to pin 8 across the rails then D1 and D5 may both be open. Pin 8 is the positive power supply. U5, the positive voltage regulator, has some short circuit protection which leaves D1 as the weak link between the regulator and the short caused by the meter leads. It is also possible that you blew (fused) the positive PC rail circuit board trace. Take a good look at the traces on both sides of the board with a magnifying glass. Also, I'm assuming you were running on AC power when you touched the meter lead. If you were running on batteries instead then I'll guess that D2 is what's toasted.
I also meant to say that the attached image above has all the measurements I took afterwards. The reference measurements are in the red boxes, and my measurements are on the outside (except for the one in the ugly red box in the middle, that is mine, and where wasn't a reference measurement). Also, I need to correct myself, I touched pin 5, I was confused on which way the pin numbering worked.
I'll take a close look at the board shortly.
Erik
Old 3rd July 2013, 01:25 PM   #3344
agdr's Avatar
Erik - I forgot about your voltage diagram. Good work on that.
You shorted out your LED and it is open. That is why you are getting +11.4Vdc on pin 5 now. With the LED gone the resistor R6 will pull that pin up to the positive power rail. Your power supplies are OK, as are diodes D1, D2, D5, and D6.
Since you were planning on getting rid of your LED anyway everything works out. Replace it with that 1.8V zener (polarity rotated) and you are back in business. If you are ordering parts it would be a good idea to get another U2 just in case.
Old 10th July 2013, 01:33 AM   #3345
Just wanted to say you are a life saver. It was just the led, I replaced it with the diode you mentioned and hooked up an led and all is working great. Going to put it back to normal after we decide on an led for my buddies build.
Thanks again!
Erik
Old 10th July 2013, 02:01 AM   #3346
agdr's Avatar
Erik - hey that is good news! You are probably one of the first to replace the O2's LED with a zener.
If anyone else needs to to do the same the zener is a 1N4614:
1N4614 Central Semiconductor | Mouser
Mouser #610-1N4614. That is a 1/4watt zener with a test voltage of just 250uA. The O2's LED circuit is running 22V/40.2k = 540uA through the LED, close enough to that zener's test current to come very close to the rated 1.8Vdc, same as the LED. Just remember to rotate the polarity of the zener from that of the LED.
Old 10th July 2013, 02:41 AM   #3347
dixter is offline dixter  United States
can I ask what officially has happen'd to RocketScientist
anybody know for sure...
thanks
Old 10th July 2013, 03:02 AM   #3348
JZatopa is offline JZatopa  United States
I wish I knew, it's always bothered me that he shared so much with the community and then just disappeared. I hope he's alright
Knowledge is Power & Applied Knowledge is Freedom,
There is no higher religion than truth
Old 10th July 2013, 07:26 AM   #3349
availlyrics is offline availlyrics  India
availlyrics's Avatar
Here is an interesting piece from Happy 2013! | JDS Labs Blog
jseaber Post author
January 14, 2013 at 7:45 am
NwAvGuy is definitely MIA. Our good friend George Boudreau (ODAC board designer) sent him a courier letter in early December. The letter was signed for, but no reply. He must have his reasons.
jseaber Post author
January 23, 2013 at 8:32 pm
@Chris: My feelings are the same. Interestingly, bursts of creativity and subsequent withdraw behavior are common amongst brilliant artists and designers.
I spoke with George Boudreau again last Monday. George claims to be one of two people in the DIY audio community who have NwAvGuy’s mailing address, and even George was given only his three initials (not even a first name!). George was asked to keep NwAvGuy’s initials and address strictly private, and he’s not even sure whether the address is a home or office.
More interesting was George’s story of ODAC development. He said that design of ODAC began after NwAvGuy had begun designing ODA. They exchanged emails rapidly for a few weeks. NwAvGuy suddenly stopped writing, disappeared for over three months straight without an explanation, and so George assumed ODAC and ODA were both dead projects! George commented that, “something serious” had happened which caused NwAvGuy to set his DIY contributions on the shelf (a family death, he believes).
Thus, it’s not absolutely certain that NwAvGuy will be gone forever. I’m sure he has his reasons.
Unfortunately NwAvGuy is MIA but he did inspired countless others to go down the Objective path!
Any self respecting headphone amp manufacturing company that is worth its salt will have its product compared (w.r.t. specs. & pricing) to O2 from now on before making any esoteric claims.
Thanks,
availlyrics
Old 11th July 2013, 12:43 AM   #3350
GeorgeBoudreau is offline GeorgeBoudreau  Canada
Default NwAvGuy
I have not heard from NwAvGuy since late July of 2013. As John wrote I did send a courier envelope to him but there was no reply. Possibly he is on the beach in California or picking oranges in Florida. His choice, his privacy.
It was fun designing the ODAC board and it took 5 kicks at the can before we were satisfied. NwAvGuy burned a lot of midnight oil fussing over the parts choices for the ES9023 which is why such a 'simple' board meets the manufacturers specs.
It would be nice if strolled back some day if only to say 'Hi'
regards,
George Boudreau
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
