Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 13th May 2013, 05:17 PM   #3291
smudgeface is offline smudgeface  Canada
Yes.
Old 13th May 2013, 05:23 PM   #3292
Still looking into the white noise I've been hearing with the ODAC and I have some interesting findings: the ODAC generates noise, even when disconnected from power. With the ODAC out of the case, isolated mechanically and electrically (except via the LOD, obviously), I can hear white noise on the amplified output when the USB cable is plugged into the ODAC and not plugged into the computer. Furthermore, if I plug the usb cable into the ODAC while listening, I can detect a short delay and a small thump before the noise starts, indicating that some circuitry on the ODAC board is being activated via the voltage present on the unplugged USB cable.
I've heard that the circuit and pcb layout for the ODAC have been maed public - can anyone direct me to it? I'd like to see if I can figure out what's going on here.
thanks!
Old 13th May 2013, 07:03 PM   #3293
agdr is offline agdr  United States
agdr's Avatar
Right here:
http://www.yoyodyneconsulting.ca/dow...AC-release.pdf (opens PDF)
from George's site here
Yoyodyne Consulting/Audio Hardware/ODAC
and more info on NwAvGuy's blog here
http://nwavguy.blogspot.com/2012/04/odac-released.html
Old 13th May 2013, 09:53 PM   #3294
Davey is offline Davey  United States
thanks!
You either have a defective ODAC and/or your testing scenario is flawed in some way. Or maybe an incorrect interface to your O2.
My ODAC is dead quiet (measurable and audibly) with (powered or un-powered) USB cable attached, or without USB cable attached. Only in the case where you powered the ODAC but did not have serial data present do the outputs show some noise. (That configuration is not easily possible to set up.)
Dave.
Old 13th May 2013, 09:58 PM   #3295
billyk is offline billyk  United States
billyk's Avatar
The same here, I have an ODAC in the same case as a B1 and a pair of Amp-Camp amps and it is completely silent, full volume, ear to the speaker, ODAC powered or not.
Hope you can find it (the noise), it is a nice sounding DAC
Old 18th May 2013, 04:28 AM   #3296
mah is offline mah  Australia
Default O2 Batteries
Would 9V 500mAh batteries be suitable for the O2?
e.g. 2 PCS 9V 9 Voltage 500mAh NI MH Rechargeable Battery Batteries 3 Years Warranty | eBay
Old 18th May 2013, 08:53 PM   #3297
generalguy is offline generalguy
Does anyone have a step-by-step guide for modding an O2+ODAC to run off just the 5V USB input? I saw that someone had done it but the process wasn't particularly clear for an electronics newcomer. I don't really run my headphones at a high volume anyway so it'd be useful not to have to lug around the charging brick.
Old 20th May 2013, 04:30 AM   #3298
availlyrics is offline availlyrics  India
availlyrics's Avatar
Originally Posted by mah View Post
RS reported unused "no name" Chinese batteries exploding on the workbench. If you want, Tenergy also offers 9V in 500mAh ver. http://www.amazon.com/Combo-Tenergy-...ews/B009MA8SAI
To reduce the chg. time you can reduce R1,R2 to 100R or 120R (same wattage) from the original 220R for 9V 500mAh batt.
Thanks,
availlyrics
Old 20th May 2013, 04:36 AM   #3299
Don't want to discourage your DIY skills but if you are new to electronics stick with the original RS design as 5V from USB involves SMPS ckts using SMD components.
Thanks,
availlyrics
Old 22nd May 2013, 03:17 PM   #3300
McQuaide is offline McQuaide  United States
Hi all, I recently built an O2 and have been enjoying it greatly. However, since I bumped up the gain on my phono preamp it's been distorting the sound pretty badly and seems to be overloaded. It sounds fine connected to a CD player.
Is there a good way to attenuate the signal so I can keep my phono preamp at 65DB of gain?
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
