The Objective2 (O2) Headphone Amp DIY Project - Page 326 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 2nd May 2013, 06:24 PM   #3251
The front panel has a brushed look that matches the volume knob. Hand sanded using 120grit sanding sponge. The fonts are silkscreened.
For the back panel fonts I use those scratch-transfer films...surprisingly they hold up well to light finger rubs (but not fingernail scratches, of course).
Old 3rd May 2013, 05:19 AM   #3252
availlyrics's Avatar
@aelfewulf
Good photos
Thanks,
availlyrics
Old 4th May 2013, 10:28 PM   #3253
I just sucessfully built an O2. Now my son just finished his build. He got U5 in backwards but he managed to desolder it and got it in right.
But now the gain switch is working backwards. When itīs pushed in the gain is lower...
And at full volume it is as loud as my O2 with the volume knob at 9 oīclock. And there is also a loud "pop" when turning on. Any suggestions???
//M
Old 4th May 2013, 11:00 PM   #3254
sofaspud's Avatar
It has the same symptoms whether AC or battery powered?
From what you've written, I'd verify the U5 operation. Then I would inspect the gain-setting circuitry around U1 and S2 (although I could probably live with the backwards switch operation, if I found it was just that the R17/R19 resistors had swapped places). Is it possible the U5 problem cooked an op amp?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 5th May 2013, 12:07 AM   #3255
Sofaspud!
Itīs the same on AC and battery. Donīt know if the U5 problem has caused anything but the opamps were uninstalled at the time for de/re-solder of U5. Will compare the resistors to my O2. How about the smaller sized caps likeC21,C16 vs.C6,C7?
Cheers!
/M
Old 5th May 2013, 12:28 AM   #3256
sofaspud's Avatar
I wouldn't suspect any of those little caps at this point. If the O2 was turned on while U5 was backwards, it may have applied incorrect voltages to the op amp supply pins. I would perform the voltage tests outlined in RocketScientist's build notes to find any catastrophic failures.
Then, if you don't have extra ICs to swap in, you could try the op amps one at a time in your working O2.
Old 5th May 2013, 12:53 AM   #3257
ericj is offline ericj  United States
ericj's Avatar
For the record, plugging the o2 into DC did damage at least one battery. I went ahead and replaced both and have good battery life again.
Sent by pneumatic tubes
Old 5th May 2013, 09:28 AM   #3258
Sofaspud!
The O2 was never turned on, or powered in any way before correcting U5 and no opamps installed at this stage. What happens if you fry U5 while desoldering it?
//M
Old 5th May 2013, 12:29 PM   #3259
sofaspud's Avatar
Frying U5 that way doesn't seem very likely. The problem presents itself with AC or battery, so the power supply isn't suspect. It is possible that you received a bad chip. A magnifying glass visual inspection of the board should rule out most construction errors. Heavy-handed soldering might damage small caps; finding the bad one could be tedious.
Old 5th May 2013, 11:04 PM   #3260
Thanks Sofaspud.
Looking a bit closer and measure it properly, I realized he had got most of the resistors in wrong. After teadious hours of desoldering (of cource I had to do it...) We got it working alright. Amazing how much abuse the board and components can take.
/M
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 06:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 03:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 04:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 03:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 16th April 2004 12:22 AM
Copyright Đ1999-2017 diyAudio
