Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 27th April 2013, 05:19 PM   #3241
JZatopa is offline JZatopa  United States
I'm curious, does the O2 circuit need any modification to drive a 47Kohm output or would something with such a high impedance not be an issue.
Knowledge is Power & Applied Knowledge is Freedom,
There is no higher religion than truth
Old 28th April 2013, 08:22 AM   #3242
LuisMCP is offline LuisMCP  Spain
LuisMCP's Avatar
Originally Posted by agdr View Post
Connecting a 10K resistor between
agdr,
It is more a big "click" than a "thump", it has more high freq. content. You can see how much is (9V peak) at image.
I attached a scope capture of G of Q1. pins D and S are also affected, signal is the same without negative part.
Forget to say that recently I build a second O2 and none of these problems was there. It works perfectly without clicks, I believe both are same version (?)
Old 28th April 2013, 09:51 PM   #3243
agdr is offline agdr  United States
agdr's Avatar
47k is perfectly OK. You can get up to the full 7Vrms out.
Old 28th April 2013, 10:02 PM   #3244
agdr's Avatar
Another thing to try is replacing U2, if you haven't already. I know of at least one case where a bad U2 was causing clicks / thumps. You would just temporarily swap the U2 from your working O2 into the other one.
Old 30th April 2013, 08:55 AM   #3245
aelfewulf is offline aelfewulf  Singapore
So here's what I did with the B3-080 chassis...built 5 of these.
Soldering all the components onto the PCB was the easy part...the remote mounting, wire cutting/trimming/soldering was the real time killer.
Old 2nd May 2013, 03:13 AM   #3246
VERTEK is offline VERTEK
02-amplifier, battery-powered at low voltage when the beep, I ask how to deal with, ah, experts know outside the grounds?
Old 2nd May 2013, 09:34 AM   #3247
availlyrics is offline availlyrics  India
availlyrics's Avatar
Impressive! Can you upload any pictures of the insides or step by step build guide?
Thanks,
availlyrics
Old 2nd May 2013, 11:37 AM   #3248
Problem solving, transistor wrong, you can FQPF10N20C, I used FQPF10N20, check for a long time could not find any problems, thank you!The following are my 02, the switch to change, and this switch is easy to use it.
Old 2nd May 2013, 03:44 PM   #3249
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Be careful when using a hot air soldering equipment. I was trying to solder the gain switch in place yesterday by using a hot air gun. It worked, but when I flipped the board over I was missing three resistors and two capacitors. They had simply fallen out. Took another hour to put them back in again :S
My audio and DIY blog: http://phimusic.blogspot.se/
Old 2nd May 2013, 05:17 PM   #3250
Thanks! Glad to oblige
The LINE-IN (blue cable) hugs the side of the chassis, away from the power circuitry and output stage. Inside the blue cable housing holds twisted pairs.
Only one battery terminal is mounted, this is necessary to hold the ODAC in place.
And here's what it looks like on the other side...
AC power line hugs the side of the chassis, under the power circuitry.
In the middle running almost diagonally is the power switch and DC rails. It's actually recycled from a spare USB cable, which I retain the red/black power line. Even the metal shielding is intact.
Finally there's the gain switch, using a recycled Ethernet Cat5 cable.
So both the AC and DC lines run underneath the board, and are thus separated from the input and output stages by the PCB.
The 2 switches and AC jack is eventually glued to the PCB using silicone adhesive.
(not shown here) the wires leading to the RCA outs have to be soldered onto the ODAC last, after screwing in the RCA jacks to the panel. I find it easier to solder to the surface mount pads meant for the 3.5mm jack.
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
