Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 21st March 2013, 03:25 PM   #3211
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Originally Posted by availlyrics View Post
Congrats-Keep up the good work. I read your blog, it reminded me of my school days when I had to borrow soldering iron from my friends to solder my broken h/p wires. Hope you build more such projects to finance your purchase of much needed measuring instruments.
Cheers!
Thanks!
Yes, in the beginning I had to borrow equipment from a neighbour. Last xmas my parents gave me my own soldering equipment so now I'm hoping to get enough customers to buy a better multimeter and some other stuff that's good to have.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 25th March 2013, 07:48 AM   #3212
availlyrics is offline availlyrics  India
availlyrics's Avatar
Originally Posted by tecnogadget View Post
...So besides the physical SIZE problem , can i use polyester caps without worrying about performance?
Go ahead with whatever is available locally,its better than using no-caps resulting large DC
BTW Gaincard by 47 labs uses 4.7 uF electrolytic i/p caps(I've read somewhere).
Thanks,
availlyrics
Old 29th March 2013, 07:57 PM   #3213
Here's a O2 powering PA spk. crazy
Objective 2 powering PA speaker - YouTube
Pls don't try this stunt on your B&W Nautilus
Thanks,
availlyrics
Old 1st April 2013, 11:39 AM   #3214
ToHu is offline ToHu
Default Thanks NwAVGuy, what a sweet package
Hey Guys, just want to share with you my accurate, none snaked oil HiFi environment, which - unfortunately for the notorious extravagant high end industry - wasn't too pricy.
@ Engineer - where have you been? People need sane, down to earth discussions so they do not get detached :-)
KR
Tobias
Old 9th April 2013, 05:56 PM   #3215
Rullknufs's Avatar
Help!
Just built another O2 amplifier. Everything went smoothly except that I accidentally put a resistor in the wrong place but I fixed that before powering it up. Also the gain switch wasn't in a good position so I had to force it down a bit while heating up the joints.
Measured all voltages as the guide says and everything seemed fine.
Powered it up, connected a source and a pair of scrappy headphones. Expected it to work as it usually does but the sound was really distorted. Tried the headphones directly to my phone and then it sounded ok. I expected the gain switch to be the fault because it was a bit glitchy and I assumed I maybe broke it when pushing it down a bit. I have now removed it, it's broken to 1000 pieces and the sound is still as distorted as before.
I have checked the voltages at D1 and D5 and all seems fine.
Edit!
"Check pin 1 and pin 7 of U1. Both should be under 0.1 volts. If either is higher, check the pins of P1 with your source connected and turned on. There should not be more than +/- 0.02 volts at any of the P1 pins. If so, there’s a problem with your source. If P1 is OK, but pin 1 and/or 7 of U1 has significant DC, U1 is somehow developing a DC offset and either U1 is bad or there’s a soldering problem with it or all the parts around it."
Did this and when measuring from negative bt1 to pin 1 and 7 of U1 I between 200-350mV peaking at about 400mV. Is U1 faulty then? I see no solder bridges and I have reheated all the joints.
Please help me. This isn't my amplifier, I'm building it for someone else.
Edit2:
I have another JRC2903D because I have two sets to build. Shall I try with a "fresh" U1? Or is there a risk that I'll trash both because there's something wrong with the board?
Old 10th April 2013, 07:25 AM   #3216
Rullknufs's Avatar
I tried with a fresh JRC2903D and the sound was just as bad as before.
I will take pictures of the amp this afternoon so you can see.
Old 10th April 2013, 07:43 AM   #3217
swalter is offline swalter  Switzerland
I would suspect the 2068 to be the culprit, had that before as well.
Good luck, Stefan
everything O2 and ODAC related can be found here: www.headnhifi.com - your DIY and audio resource
or have a peek in our vendor forum: http://www.diyaudio.com/forums/head-n-hifi-walter/
Old 10th April 2013, 08:05 AM   #3218
Rullknufs's Avatar
Good luck, Stefan
Tried with a new fresh one. Same problem.
Edit: Oh god what an idiot I am! I had mixed up U1 and U2 so the 2903 was U1 and the 2068 was U2. Put them back correctly and now everything works as a charm. The only problem is I have trashed the gain switch by prying it loose from the board because I thought it was faulty. Is it some sort of standard component that I can find locally in Sweden? Or it is something that can be left off the board?
Old 10th April 2013, 08:17 AM   #3219
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I don't know about parts availability in Sweden, but you can leave it off the board. Just pick what gain you want (no switch = no switchable gain) and jumper the connections. Use a cutoff component lead or piece of solid copper wire and it will be easy to remove and install a new switch at a later date.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 10th April 2013, 08:24 AM   #3220
Rullknufs's Avatar
Is it even necessary to jumper the connections? I have installed the standard gain resistors and now without the switch gain seems to be 2.5x. Might be 1x too though, not sure.
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
