Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 20th March 2013, 09:51 AM   #3201
availlyrics is offline availlyrics  India
availlyrics's Avatar
Originally Posted by weslito View Post
I don't have a bookcase, but I do have a benchcase
Wow- what a setup! I'm too embarrassed to show my bench case. Maybe I will PM you my setup snaps
Thanks,
availlyrics
Old 20th March 2013, 10:16 AM   #3202
Originally Posted by Namenlos View Post
This can't work, you just increase the load of the preamp. You have to create a voltage divider somehow.
Sorry for the unintended confusion.
With 4.7K (connected from centre to gnd of pot)
You get 3.2K pot
With 10K
You get 5K pot
With 40.2K
You get 8K pot
All combinations are above JRC 2068 lowest RL limit of 2K.I would highly recommend 10K as you may have extra pair in hands from BOM.No harm in trying. If this doesn't works for you can always clip the resistors.
BTW pot linearity will be thrown out of window.
Pls refer to attch. schematic.
Thanks,
availlyrics
Old 20th March 2013, 11:21 AM   #3203
Default O2 with stepped attenuator
Here are some photographs of my "Fossilised" O2 with stepped attenuator(11+1 steps)
PCB is mounted on brass studs separated by anti-static plastic sheet from the main body to prevent any accidental shorts. It has RCA i/p which are automatically disabled when 3.5mm i/p connector is inserted from front panel. The bare outer ring of RCA i/p connects i/p Gnd. to tin box reducing noise. Jumpers are used instead of gain switch giving me 3 gain options(1X,2X,8X).
Resistor values used in stepped attenuator 100,180,390,680,910,1K,1.2K,1.5K,1.8K,2.2K,2.7K (hand-matched).
It gets comfortably loud at 1X gain with RCA i/p from consumer DVD player , 2X from my laptop & 8X from ipod touch for my Superlux HD668B(56 Ohms, Sensitivity 98dB)
The vacant space(foam)will be used for installing DC protection relay circuit & 1/4" socket. Non-standard red LED used (fwd. drop of 1.78V) with R6 (33K) as suggested by agdr. PM circuit works like a charm.
Thanks,
availlyrics
Old 20th March 2013, 05:43 PM   #3204
Namenlos is offline Namenlos
You get 3.2K pot
With 10K
You get 5K pot
With 40.2K
You get 8K pot
This does not work that way. You basically would get another taper characteristic and an uneven load with this. Mostly it would just attenuate the higher gain settings. With 4.7k parallel and the volume at 50% you would get about 16% less voltage which would just be 0.75dB at lower gain settings it is even less than that.
Old 20th March 2013, 07:17 PM   #3205
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Finished my third O2+Odac combo today. Set a new personal speed record too, total build time was about three hours I think.
I have a step-by-step construction guide coming up on my blog within the coming days.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 21st March 2013, 02:38 AM   #3206
tecnogadget is offline tecnogadget
Hi! Im having tome trouble to find some parts here in Argentina.
What if on C13 and C14, instead of the Metal Film Polyester BOX capacitor i just use regular Metal Polyester ones like in the picture above?
http://theonlinetutorials.com/theonl...Capacitor1.gif
Will this change the operation of the amp? Change the sound of it?
Im the kind of person that chooses Rubycon caps over no brand caps , i think that matters.
And concerning the potentiometer , i cant get anything better than this.
http://www.onlinetps.com/shop/images...entiometer.jpg
How much matters if i use a cheap chinese pot instead Alps or Bourns ?
Cheers , Stefano
Old 21st March 2013, 04:05 AM   #3207
Yes you are right on "uneven load" as seen by 2068 with added non linearity issues, but I've seen those type of implementation in electronic fan regulators
Chk this for more info
ESP - A Better Volume Control
BTW What is your music source? Can't you control vol. from there?
Thanks,
availlyrics
Old 21st March 2013, 04:48 AM   #3208
Originally Posted by tecnogadget View Post
...Will this change the operation of the amp? Change the sound of it?
I'm no expert on caps, but you will have hard time physically fitting non-standard BOM components. Believe me I've done that.
As for pot-don't even bother with cheap Chinese dump, you can short appropriate holes giving you full vol. from O2 & you can control your vol. from your source with its own digital vol. control(far better tracking than Alps or Chinese pot). Above all when those Chinese pot. wear out, you will have hard time de-soldering again.
See attch. for my implementation
Thanks,
availlyrics
Old 21st March 2013, 05:31 AM   #3209
Congrats-Keep up the good work. I read your blog, it reminded me of my school days when I had to borrow soldering iron from my friends to solder my broken h/p wires. Hope you build more such projects to finance your purchase of much needed measuring instruments.
Cheers!
Thanks,
availlyrics
Old 21st March 2013, 03:04 PM   #3210
I know the non-standard BOM cap is larger , but i won't be using the official aluminium enclosure so that is not a problem. Your volume implementation is very clever , but does not suit for me , since i will connect the iPod Touch with a Line Out cable (3.5mm to 30pin Apple connector) , so the signal is sent at full vol. so i need to change it on the amp.
Thanks for your reply availlyrics
So besides the physical SIZE problem , can i use polyester caps without worrying about performance?
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
