| Headphone Systems Everything to do with Headphones |
#3121 | |
Sent from my mobile thinger using the tapawhatsit |
#3123 |
Has anyone tried out the LME49990 on the O2?
#3124 |
The LME49990 is a fantastic part. OPC used it in the "Wire" headphone amp. The THD + noise vs. frequency graph is just amazing. But unfortunately it wouldn't work/fit in the O2. The 49990 is only available in surface mount and only in single op-amp packages, vs. the dual op-amp through-hole NJM2068 in the O2.
#3125 | |
Dual SOIC LME49990 DIP8 Adapter | eBay |
#3126 |
Lol! You've got me there.
That is a good find. I'm always surprised at what is out there. ![]() The other problem though is the AC specs of the NJM4556A output chips are rather hideous compared to the LME49990 and would likely cover up any improvements. Check out the THD vs. output voltage graph in the NJM4556A data sheet: http://semicon.njr.co.jp/eng/PDF/NJM4556A_E.pdf That is for a gain of 30dB, so luckily things get better at unity gain as RocketScientist's measurements showed. But... I'm always one for trying things! From the specs the 49990 should work, and at that relatively low price it would be fun just to try. |
#3127 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I just had a look at the LME49990 DS but they're too coy, they don't show what JRC show here - how THD vs level varies with frequency. But the THD plots do show a rise at 20kHz.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart Last edited by abraxalito; 14th February 2013 at 02:30 AM. |
#3128 |
"....I think The Wire is a solid design and I like the LME49600 a lot. I also like the fact he ran Audio Precision measurements to prove the performance--that's very rare in DIY. On the downside I think The Wire is more expensive than it needs to be. It also uses surface mount parts which are a challenge for some people.
I started a DIY audio thread regarding a more simple design ( http://www.diyaudio.com/forums/headp...n-project.html ). We got a bit off track in the thread, but I'm still researching similar designs. My goal was a reasonably priced, no BS design, that's easy to build and performs well....." Quoted by RS in user comments NwAvGuy: Cmoy eBay Headphone Amp As for opamp rolling in O2 read, "....In other words, without updating the rest of design (perhaps including even the PC board), the op amp may be at least somewhat unstable or otherwise unhappy. And because most instability is at ultrasonic or RF frequencies, the person doing the swap may not even know they just took a giant step backwards. Even RMAA can’t “see” ultrasonic and RF problems..." http://nwavguy.blogspot.in/2011/08/o...ths-facts.html IMHO LME49990 or 49600 will require very careful PCB layout (not the O2 PCB layout)
Thanks, availlyrics Last edited by availlyrics; 14th February 2013 at 07:13 AM. |
#3129 |
Quick question I haven't built my O2 yet (I have the material), but from my first experience with the cMoyBB, I noticed that a few of the joints are black by accident. Is that a very bad thing; should I desolder it? Or is the reason it is black is because I've heated it too long by accident? It might be one of the joints that I reheated and reapplied solder with desoldering it first, I am not very sure.
Also, to clarify, too less solder on IC -- or basically any parts with extremely small leads -- is fine as long as it covers the lead up? Generally, although it is both bad, less solder > more solder? One last soldering question: Does it damage the lead or pcb a lot when I reheat it for the purpose of desoldering it, then reheating it for the purpose of soldering it? |
#3130 |
Black solder joints? Definitely no good.
I can't say for sure why it's black. A contaminant or overheating? Or both? Those joints should be desoldered and redone. Apply flux and don't use more heat than is necessary for a good shiny fillet. I wouldn't say a joint has to have a perfect fillet with ~45° slope. There shouldn't be any voids in the hole alongside the lead - that's a sure sign of insufficient solder. Too much solder is bad also. My advice is don't settle for too little or too much; get it right and it will eventually become second nature. No damage is done by soldering/desoldering if it is done right. If you "can't get it," pause and let all the parts cool down. Don't fight it with the soldering iron stuck to the board.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
| Headphone amp project | grahamfocal | Headphone Systems | 7 | 21st June 2011 05:28 PM |
| My latest project - DAC + headphone amp | gmarsh | Digital Line Level | 105 | 13th December 2010 02:31 PM |
| My headphone amp project | trifidmaster | Headphone Systems | 2 | 22nd December 2008 03:52 PM |
| Mini Ipod headphone amp DIY project | Nordic | Headphone Systems | 14 | 11th March 2007 02:35 PM |
| Need help for a battery headphone amp project | dismalonyx | Headphone Systems | 1 | 15th April 2004 11:22 PM |
