Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 9th February 2013, 08:19 PM   #3111
ericj is offline ericj  United States
ericj's Avatar
Originally Posted by DevilsRightHand View Post
All the parts were in the same bag, so I had to check the values of each resistors, which is easy, but now I have 8 ceramic caps that I can't figure their values. Here's what I have:
4x with BC 221 on it
2x with BC 105z
1x 223 E1M
1x 213AFP
That's what is writen on them an I don't know what it means
Why not compare the numbers on the parts with the values in the bill of materials?
Sent from my mobile thinger using the tapawhatsit
Old 9th February 2013, 09:09 PM   #3112
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Those number codes signify picofarads. 1st digit, 2nd digit, tens multiplier. So...
221 = 220pF (C11, C12, C19, C20)
105 = 1000000pF = 1μF (C1)
223 = 22000pF = 0.022μF
213 = 21000pF = 0.021μF
The last two are for C16 & C21. Probably an availability issue, so a cap 1 nanofarad less was substituted. Virtually no difference where it's used in the O2 power management circuit.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 11th February 2013, 02:41 PM   #3113
hedphones is offline hedphones  Finland
I had difficulty with those capacitors, too, but I guess I got them right. Mine were also different than what they were in O2 reference pictures. Capacitor calculator really helped with them.
Anyway, my subject was that I just plugged my O2 to a DC adapter and now it outputs no sound anymore. It still "works" with one battery though, but clips very badly.
Where could I get some spare parts for the O2 in EU? Also do you know which parts could potentially be broken with it?
Old 11th February 2013, 03:24 PM   #3114
ericj's Avatar
If you go back a couple pages, when I did that it cooked the 4556 chips. It sounds like you are down a battery too? Make sure you replace the damaged one with the exact same, or just replace both.
Old 11th February 2013, 06:52 PM   #3115
defi is offline defi  United States
I just got done soldering the O2 and I have to say that I am quite impressed. However, I have some opamps from previous projects such as the LM4562, AD8066, AD8620, etc. If I were to try these out in the O2 build, which slot do I switch them into? U1, U2, U3, U4? Thanks!
Old 11th February 2013, 08:05 PM   #3116
ericj's Avatar
4562 and 8620 may replace the 2068 effectively. 8066 may be too fast of a chip for this board. Or not.
Give the stock parts a few hours burnin and you will be even more impressed. And i do mean few.
Old 12th February 2013, 04:01 AM   #3117
availlyrics is offline availlyrics  India
availlyrics's Avatar
Originally Posted by gootee View Post
....There's bypassing and there's decoupling....
Good explanation, I will be reading more on "Power Supply Resevoir Size" .
Thanks,
availlyrics
Old 12th February 2013, 04:15 AM   #3118
...Anyway, my subject was that I just plugged my O2 to a DC adapter and now it outputs no sound anymore. It still "works" with one battery though, but clips very badly....
For spares take help from swalter of "head n' hifi".
BTW What really happens if you connect DC adapter? Does the o/p is busted if h/p is connected apart from 1 bat. not getting charged? Or does the PM of O2 offers some protection from DC adapter.?
I wont be doing this trial/mistake on my O2
Thanks,
availlyrics
Old 12th February 2013, 01:28 PM   #3119
I measured my batteries, they were about 8.8V each. Anyway weird thing, yeasterday my O2 worked for few minutes fine, but then as I turned power on and off, it stopped working again.. I'll take some measurements and post here later..
Old 12th February 2013, 04:45 PM   #3120
swalter is offline swalter  Switzerland
The last two are for C16 & C21. Probably an availability issue, so a cap 1 nanofarad less was substituted. [...]
Hi, finally found some time to read up on the thread.
I guess the set came from me, just to point out that the caps are actually packed like this from mousers supplier, I just take two out of a bag of a thousand and do not really read what is printed on them when preparing the kits.
Taking the tolerance of 20% into account those caps have, even a 173 would still be within specs as long as it has a tiny bit of positive tolerance
Stefan
Stefan
everything O2 and ODAC related can be found here: www.headnhifi.com - your DIY and audio resource
or have a peek in our vendor forum: http://www.diyaudio.com/forums/head-n-hifi-walter/
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
