Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 4th February 2013, 06:17 AM   #3081
availlyrics is offline availlyrics  India
availlyrics's Avatar
You don't scare me
Actually, I forgot to order them & only the ordinary ceramic types are available locally. I dont want to wait for another 15 days for it to arrive.
I'm more concerned from ckt. stability point , thankfully I donít have golden ears to diff. between various capacitors.BTW I've read somewhere that SMD ceramic cap. are C0G only
Thanks,
availlyrics
Old 4th February 2013, 07:28 AM   #3082
qusp is offline qusp  Australia
qusp's Avatar
C0G/NP0 have better Tempco and Voltage coefficient. C0G vs X7R or less, generally C0G are made to a higher quality and can cause lower distortion due to the second factor. they are critical for timing and compensation circuits and have measurably lower THD depending on where they are used. no golden pinea arguments here, very objective.
but no, not ALL SMD caps are C0G, not in the slightest
Old 4th February 2013, 09:32 AM   #3083
Originally Posted by qusp View Post
...but no, not ALL SMD caps are C0G, not in the slightest
That cleared my doubts
Thanks,
availlyrics
Old 5th February 2013, 02:45 PM   #3084
ramsfan6239 is offline ramsfan6239
I have a problem with my o2 amp,
I tried it with several sources, and each one gave the same result. The light comes on but there is no sound when the unit is switched on with battery power only. If you either start it on wall power and then remove the wall power, or start on battery power and then plug in wall power and remove it, then it runs fine on battery power. The key here is that it will run fine on battery power as long as it has been plugged into wall power, even for a moment, sometime after the power has been cycled. I can't see how any flaw with my several audio sources or a flaw with the batteries (I did try another set of known good batteries, by the way) could cause this strange behavior. I'm guessing that it might have to do with the power control circuit.
Any idea on where I should troubleshoot?
Old 5th February 2013, 02:53 PM   #3085
6L6 is offline 6L6  United States
6L6's Avatar
Please post well-lit, in-focus photos of your PCB from a few angles. That will help us immensely.
You will be amazed at what some people can spot on a photo!!
Old 5th February 2013, 05:58 PM   #3086
jtktam is offline jtktam  Canada
the batteries are out of sync, if you have a standalone 9v charger, then take out of the o2 and charge them to full.. once you do that and put them back into the amp, it will work correctly..
next time don't run the battery down to a level where they are uneven
-joe
our diyaudio forum - post your questions here
Audio Poutine - full web site coming soon
ODAC/O2 parts or assembled - Google spreadsheet
Old 5th February 2013, 09:23 PM   #3087
I will do that in a moment!
-joe
Both batteries are fully charged - Tested with a multimeter at 9.2 ish volts, and there is maybe a tenth of a volt between the two.
Old 5th February 2013, 09:27 PM   #3088
ramsfan6239's Library | Photobucket
There are a bunch of photo's, they will be the first 6 or so. If you need me to take more let me know.
-Tyler
Old 6th February 2013, 11:58 PM   #3089
WildChinoise is offline WildChinoise
Wow! I stumbled upon this one a few days ago and have read all 3000+ messages. Kudos to the great support you are lending to each other and to the newbies that are asking for help. I'll be one of those fellows in a month or so after I clear some other items off my desk first.
And especially thanks to the RocketScientist for the great effort he put in!
Old 8th February 2013, 03:27 AM   #3090
Bassd is offline Bassd
Hi guys, new to DIY. I ordered the kit from headn'hifi, I know how to solder and have all the right tools. BUT I can't work out how to sort and label all the parts I got and match them with the reference numbers on the BOM.
main problems is the tiny resistors. Do I really have to look at each color code and slowly decipher them? Only problem there is the resistors seem to have 5 stripes and i'm not sure how you tell which end to start at.
Sorry for the novice questions
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
