Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 10th January 2013, 04:35 PM   #3031
ericj is offline ericj  United States
ericj's Avatar
Originally Posted by MGeeOne View Post
Thanks for the blog headsup...will digest over the next few days. Then straight to HnH!
Will look out for a suitable PSU too...in fact that might be another good DIY maybe?
The o2 has a very good on-board psu. It just needs ac voltage. I recommend something like the antek an-0109 toroid with it's dual secondaries wired in series for 18vac. Costs $10 and they have 76 of them in stock. Other than that, you could use a filtered ac inlet.
Sent from my DROID4 using Tapatalk 2
Old 10th January 2013, 05:13 PM   #3032
keithostertag is offline keithostertag
Originally Posted by qusp View Post
because by moving the gain switch to the panel you are taking the feedback loop out to the panel with it and thus increasing the length of the loop and decreasing stability, increasing noise pickup etc.
OK, thanks. Could you elaborate a little more? As long as the wires I use are shielded, how does that decrease stability? If properly shielded, how does the length affect it?
I'm new to this so I'd like to understand a little more about it.
Old 10th January 2013, 05:24 PM   #3033
Default A few parts substitution questions- LED, NJM2068DD, C1, C6, C7
Hey guys-
For those who have mounted the power-on LED on a remote panel, what did you use? I see the cautions about it requiring an HE led, etc. Mouser part number?
Mouser is out of NJM2068DD for the next three months. I can order the "noisier" NE5532AP for now and substitute later, but wondered if any other options have emerged.
Also, for C1, C6, and C7 the 1uF 25V cap which is stated as a "non-critical part", any problem using a tantalum? I know tantalums sometimes get a bad rap, but AFAIK they are OK as long as they are voltage rated properly. I happen to have a bunch of tantalum 1uf 35V.
Thanks,
Keith
Old 10th January 2013, 05:26 PM   #3034
ericj's Avatar
Shielding adds capacitance that could make it worse.
There are electromagnetic waves all around us that can induce signals into the feedback loop and cause distortion or even cause the chip to oscillate. Longer wires are bigger antennas, and the gain switch is a particularly sensitive area.
Old 11th January 2013, 01:20 PM   #3035
OK, thanks Eric.
I found the info I needed to test for appropriate LED's on a few pages from October, thanks ADJR and others for such detailed explanations!
I still haven't found a good resolution schematic... the one on Googledocs is practically unreadable.
Keith
Old 11th January 2013, 02:38 PM   #3036
shadow419 is offline shadow419  United States
Have you tried zooming in on the pdf? It works fine for me on my browser
Old 11th January 2013, 02:45 PM   #3037
Yea, tried that. Resolution is so bad I can't read the schematic clearly. NwAvGuy's page says there is a high definition copy somewhere, but all I see are links to the GoogleDocs version.
Thanks,
Keith
Old 11th January 2013, 02:51 PM   #3038
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Thanks,
Keith
See the attached PDF. It is high res enough if you use Adobe Reader.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 11th January 2013, 03:22 PM   #3039
Great! Much better! Thank you so much!
Old 11th January 2013, 06:01 PM   #3040
ramsfan6239 is offline ramsfan6239
Guys - I need help.
I'm doing an amp and I have a problem I can't fix.
so here is the problem - at low volumes, and at full volume on the potentionmeter, both left and right cups sound the same, anywhere in between, the right channel is very quiet, off balance.
I have tried - Replacing all mosfets, replacing the 2068dd opamp, potentiometer, replacing gain switch, checked all resistors, all diodes are in correct position, re soldered the whole board... I can't figure out what's going on.
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
